Go to Post Now Dave, before you get all snarly about these- remember, I still have the button maker... - MissInformation [more]
Unread 18-01-2006, 15:24
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Shaft size of Big "FP" CIM Motor
Does anyone have the size of the output shaft for the new big fisher price cim motor after the belt sprocket is pressed off. A sketch of the length width and if there is a key would be nice.
Thanks, I don't want to press the sprocket off to find out and the motor is on the other side of town.
Unread 18-01-2006, 17:46
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Shaft size of Big "FP" CIM Motor
I have it on reliable source that it is 5/16" with a flat ground on one side.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-01-2006, 18:05
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Yes, that's what it appears to be. 5/16 and flat ground on 1 side. However, though it's not a big difference, because it's in the CIM family, might it be 8mm output shaft?
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 18-01-2006, 18:32
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Hmmm I thought it was 8mm (.315"). It is only 2-3 thousandths of an inch differenence (5/16=.3125")
Anybody have a tie breaker?
I just check the step file on AndyMark.biz: Andy has modelled the shaft as 8mm with a flat at distance of 3.531mm (.139") from the centerline (= 7.531mm= .269" from the OD opposite the flat to the flat).
I hope this helps.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
IGES Model of Large CIM Motor Madison SolidWorks 7 16-01-2006 13:27
Large CIM motor specs ryan_f Motors 4 13-01-2006 21:38
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
