Labview problem is with the COM port.
CMUcam2 v1.01 c7 Error Code: -1073807202 Error String: Property Node in VISA Configure Serial Port (Instr).vi->CMUcam2.vi->CMUcam2 GUI.vi We have the camera set up using labview. Everything works fine. We have a second computer where we are playing with the c code. Labview works on first computer. Gives the above error on the second computer. First computer is a desktop, second is a laptop with a serial port. HELP. We have read all the posts and tried what we could. No luck. Thank you very much for your help -Team 354 |
Re: Notes on the camera
Oh ya,
Under the serial port menu in Labview, nothing is showing up. Just "refresh." nothing else and refresh doesn't help. thanks -354 |
Re: Labview CMU Camera COM Port Help
We did read previous posts...
TTL Cable not connected, port baud settings are correct. |
Otherwise, I had that same problem and found out the serial cable wasn't in all the way. |
Good luck! -Joe |
