Go to Post We all change, and we need to make sure that we can grow and change together in a positive way. Keep close the people who are capable of doing this with you, and you will surround yourself with the tools for success. - Jaine Perotti [more]
Unread 18-01-2006, 20:11
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Grinding down skyways
I am wondering how people grind down the skyway wheels when they don't have a lathe?
Unread 18-01-2006, 20:13
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Re: Grinding down skyways
I remember at competition we just ran the bot and held a file up to the wheel, if you have your drivetrain setup run it and just hold a file to the wheel, but as always be very careful when you do this make sure you're being safe.
Penn Class 08
Unread 18-01-2006, 21:27
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Team Role: Mechanical
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
safety is key but try to put the file in a place so that the end is wedged against something such as the frame so you can put a lil more leverage on it and grind faster. this is really messy so i suggest put down like newspaper first to speed clean up or do it outside or better yet get a shop-vac
MechWarriors 573
Unread 18-01-2006, 21:30
DonRotolo's Avatar
Back to humble
FRC #0832
We used a belt sander instead of a file, holding the sander at almost a 90 degree angle to the rotation.
Don
Unread 18-01-2006, 22:45
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Last year our team took a belt sander to the skyway wheels with them latched in a vice. We had someone do them very evenly.
Then we got some of the wedge top tread from mcmaster and cutout strips to go around the wheels.
We then lined the outer edge of the wheels and the bottom of the tread with E6000 (great stuff) which you can usually find in most craft stores actually (not sure why, its a super strength glue)
Next, we tie-wrapped the tread around the wheel. finally, we drilled out holes to put in two pop rivets on each end of the tread, and riveted them in.
One night later, and we had super treaded skyways.
just take off the tiewraps and they're set.
You may want to use a stronger epoxy to hold on the tread, and possibly add a few more rivets around the wheel. They held up great in competition though, and gave us lots of traction.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 18-01-2006, 22:53
Unsung FIRST Hero
Karthik Karthik is offline
VEX Robotics GDC Chairman
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I've moved the posts about design sharing to http://www.chiefdelphi.com/forums/sh...threadid=42172 . Should be some interesting discussions.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 18-01-2006, 23:05
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
We did something very similar last year, and all we needed was a few small wood screws to keep the tread on .
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 18-01-2006, 23:15
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
http://www.team1369.org/team13692/Ph...%201%20014.jpg
http://www.team1369.org/team13692/Ph...%201%20021.jpg
We took the skyways to a lathe and took them down significantly....because they are a glass filled polymer we need to keep sharpening the tooling we used, but from there we drilled through and pop rivetted them on. I would reccomend it to anyone using a skyway wheel.
Grinding Down Drill Motor Gears fred Motors 3 21-02-2004 22:13
Okay, 6 or 10 Skyways? archiver 2001 1 24-06-2002 01:00
