Go to Post Smokey the Fisher Price motor says only YOU can prevent rule infractions. - artdutra04 [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 19-01-2006, 00:21
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
3D Animation Q/A
I felt like making this thread since we all have questions, or at least most of us, on how do one thing or the other in 3D Max. So for the first question: I would liked to know how add thickness to an object. Ex. say I wanted to make a trash can, just a cylinder that gets fatter towards the top the one you find in your bathroom or bedroom. Anyways I need to make the trashcan look like it thick and not just a round piece of paper. If you can picture, I was if you can help me or aim me and to get better description on what I want to do.
Hear about the cannibal that passed his brother in the forest.
Unread 19-01-2006, 00:53
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: 3D Animation Q/A
do you want to make it thick using materials or just modelling? For modelling, you can use the "Tube" standard primitive and then apply a taper modifier to it.
Unread 19-01-2006, 01:09
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I would have no clue how to do with materails, but I will try that. Only problem now is taht my dad's computer is used as the server for 3ds max license so i cant access it till tom.
Unread 19-01-2006, 07:19
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
or you could just make the trash can like you would normally, and when you want to make it have thickness, apply the shell modifier to it. this also works onplanes for making sheets of glass, plywood, anything like that instead of using boxes.
Unread 19-01-2006, 07:41
Brindza's Avatar
Brindza Brindza is offline
AKA: Jordan
FRC #0888 (Robotiators)
Team Role: Operator
Brindza is a jewel in the roughBrindza is a jewel in the roughBrindza is a jewel in the roughBrindza is a jewel in the rough
Send a message via AIM to Brindza
You can just make a cylinder shaped object and extrude the top face down into it shrinking or expanding the vertices to make it smaller at the bottom
Unread 19-01-2006, 15:41
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
You mean edit poly the cylinder and then vertex extrude or polygon extrude? I have already tried polygon extrufe and it doesnt work right. Extruding the vertexes would work if there was an easy way to have the connect back to the original cylinder, anyway to do that?
Unread 19-01-2006, 18:17
Brindza's Avatar
AKA: Jordan
Team Role: Operator
I was talking about the extrude face feature.
3dsmax should have an option that allows you to select a face and then extrude it.
It will make another face with the same dimensions and connect the vertices of the 2 face with other faces.
Unread 19-01-2006, 18:29
daniel.thyrso's Avatar
daniel.thyrso daniel.thyrso is offline
Programmer
AKA: Daniel Thyrso
FRC #1382 (TribotecTeam)
daniel.thyrso is an unknown quantity at this point
Well, it already has,
Build a box, apply edith mesh to it, press 4 then find the extrude button, right above the the bevel button......
daniel.thyrso@gmail.com
Team #1382 - Tribotec Team - NJ Regional
www.tribotecteam.com/forum
Unread 19-01-2006, 18:55
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
tried it doesnt work there is a gap in between the extruded faces. Works for square surface but not round ones.
Unread 19-01-2006, 19:59
animator1's Avatar
animator1 animator1 is offline
Animator
FRC #1312 (Syntax Error)
Team Role: Animator
animator1 is an unknown quantity at this point
ok, i was wondering if i can put an animated character into a real life scene for our animation? is that possible? or does it have to be just animation and no rea life video?
Unread 19-01-2006, 20:12
Animator
Team Role: Animator
yes. it's called video compositing. i'm not entirely sure how to do it, but you could prolly find a simple tutorial in max or online.
Unread 19-01-2006, 20:26
BruceJ BruceJ is offline
FRC #0111 (WildStang)
Rookie Year: 2000
BruceJ will become famous soon enough
Are you allowed to? Certainly!
Is it possible? Of course!
A simple method is to go to the Rendering menu and choose "Environment".
Set the environment map to open either a video file (AVI or MPeg) or a sequence of numbered images like JPGs or TGAs.
Now when you render the scene, the objects in the scene will appear in the foreground and the video you imported will be behind the objects.
If you need to do more complex things than that, then I would suggest using a program like Adobe Premiere or Adobe After Effects to combine your animated output from 3ds max and your video files.
Unread 19-01-2006, 09:03
Amittt Amittt is offline
FRC #1578
Amittt is an unknown quantity at this point
Ok, here is a problem i have already published...
I wanna export a robot that was built in pro desktop and import it with 3dsmax 8
When I import a .STL file it shows me a message:
"bla bla bla design1.stl is not a valid *.STL file"
This file was exported from autodesk pro desktop 8.0 in this way:
File --> export --> browse --> choosing the file --> save --> ok.
if you can help, pleaseeeee...
Ok, now I tried a diffrent file type: *.IGS
I exported it from pro desktop 8.0 in the same way and imported it in 3ds max.
A simple object like a square was imported perfectly to 3dsmax 8, but when I tried importing a complicated structure like a base of a robot (which was built from several other designs which were connected to one design) it didn't import nothing.
please, help.
Thanks a head, animation team, 1578.
Unread 20-01-2006, 09:24
Corporat's Avatar
Corporat Corporat is offline
Mama mia, that'sa one spicy robot!
AKA: Anthony R
FRC #1676 (Pascack Pioneers)
Team Role: Animator
Corporat will become famous soon enoughCorporat will become famous soon enough
Send a message via AIM to Corporat Send a message via Yahoo to Corporat
please, help.
you could try to export as an autoCAD file (or something else) and then from AutoCAD export as a 3ds file. Tell me if it works out.
  #15   Spotlight this post!
Unread 20-01-2006, 23:56
Nuttyman54's Avatar
Mentor, Tactician
I've found that AutoCAD's .3ds export doesn't work that well (Curves get pretty screwy), but that exporting as a .igs from AutoCAD and then importing THAT works quite nicely...odd but true
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
