Re: 3D Animation Q/A
Well i finally got around to working on the trashcan again and when I made it using a tube, I can't figure out how to close the hole on the bottom of the tube any suggestions?
the easiest way to make a trashcan is to use a cylinder, delete the top, and adda shell modifier. shell just makes your 2-d objects have thickness.
if you have to do it with a tube, selcet the vetices on the inside edge of the end of your tube, like where the bottom will be, and scale them down until they are close enogh to weld into one vetex. that will give you issues, though. for the easiest solution, you should just go ahead and plug the bottom of the tube up with a cylinder. |
Better base. make the base a tinny part of a hemisphered sphere. And make it white with an anisotropic specular. |
How do I stop selecting a selection class? It just won't stop!
#11
I love 3d studio max 8 so much
#13
I was wondering if anyone knew how i could change a question mark, into an exclamation mark in 3ds max? is it using a modifier? is it even possible? if not i will just stick to my original plan.
#14
take a box, apply a bend modifier to make the '?' and then straighten it out so it forms a '!'
that's the only way I know... |
#15
The box thing didn't work.But what i was thinking of doing was using it with text.
| Animation Question | Velaes | 3D Animation and Competition | 15 | 02-02-2005 00:11 |
| FANATIC - Offseason Animation Competition | opnickc | 3D Animation and Competition | 15 | 10-06-2004 20:54 |
| A solution for Animation Judging for 2005 | TKatsAniMentor | 3D Animation and Competition | 26 | 04-04-2004 15:29 |
| A joke they called Regional Animation Competitions | Lev | 3D Animation and Competition | 50 | 18-03-2003 21:18 |
| How to develop your animation idea and keep your sanity too! | Robby O | 3D Animation and Competition | 0 | 25-01-2002 01:25 |
