Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 19-01-2006, 02:07
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
CMUcam2 code for EDU-RC?
Will the CMUcam2 work on the EDU-RC controller?
If so, is it the same code?
and Do I use the TTL port (I just want to make sure its the same and I don't burn anything out) on the EDU controller?
Unread 19-01-2006, 14:10
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: CMUcam2 code for EDU-RC?
yes, yes, and (checks own edu controller) yes.
as kevin said, the cam code was designed witht the edu controller in mind.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 19-01-2006, 14:47
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
I haven't seen our EDU controller in a while, does the TTL port have 3 pins or 4 pins? I wanna say 3 and if so do we need all 4? I assume not since only 3 go to the camera, but the TTL adapter still has four pins, so which 3 do we have to align?
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 19-01-2006, 14:53
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
This should answer your question. The picture is take from page 11 of the 2005 RC reference guide (http://robotics.dyndns.org/DATASHEET..._RC_GUIDE.pdf), and the EDU diagram is taken from page 11 of the 2004 EDU reference guide (http://robotics.dyndns.org/DATASHEET...EDU_GUIDE.pdf).
Obviously, the +5V pin on the full-size RC is not needed.
ID:	3856  Click image for larger version
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 19-01-2006, 15:23
Matt Krass's Avatar
AKA: Dark Ages
Thanks.
Matt Krass
Unread 19-01-2006, 16:16
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Thanks.
You'll need to hack a cable and pull 5V from one of the PWM or digital input pin sets to power the TTL converter.
Unread 19-01-2006, 17:09
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Or just use the programming port.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 24-01-2006, 08:49
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
-Kevin
The DB9 port? And do we then need to change the serial port used in the code?
Jon Mittelman
Unread 24-01-2006, 01:58
lkdjm's Avatar
lkdjm lkdjm is offline
AKA: David Mazza
FRC #0564 (Digital Impact)
lkdjm will become famous soon enough
Send a message via AIM to lkdjm Send a message via Yahoo to lkdjm
AHH! I'm getting lost, someone has to fill me in!
I am a newbie . What do you mean by "hack a cable" and how would this cable look/work? do you need to "hack a cable" for the edu bot and the frc bot? or just one. do you use a pwm cable to go from ttl to ttl port? I could not find anywhere what cables you use where? When do you use the ttl chip that came with it? Is that only for testing? One person said "obviously you don't need the +5v" and the other said to "hack a cable" so I am very confused. I have been tring to get the camera to work for a few days. The only led that comes on is green, and I think it is the power one. I have gotten the camera to center itself, that's it. grrr, I feel like everyone has figured this out but me.
I know this might be a lot to ask but could someone make a quick schematic on paint of all the conections you need to get the camera to work? I have not found any good solid and simple info or diagrams in any documentation, so I think that would be REALLY HELPFUL to alot of people!
I know that is alot of questions so thanks for all your help in advance!
I should probably create a new thread for this but I know people don't like that.
-David Mazza
-Team 564
-564.first@gmail.com
Longwood's Digital Impact
Unread 24-01-2006, 02:32
Eldarion's Avatar
Re: AHH! I'm getting lost, someone has to fill me in!
-David Mazza
-Team 564
Just verifying something, are you trying to run the camera on the full-size RC (the one used in competition this year) or on the EDU controller from 2004?
This thread is for "hacking" the CMUCam to run on the EDU controller.
-- Thomas Paine
-- Anonymous
Unread 24-01-2006, 03:57
lkdjm's Avatar
AKA: David Mazza
Both! The EDU to test, and FRC to use. I would like to know how to hook it up to the EDU. I am mainly wondering how the TTL thing gets setup. After I know how to run it on the edu I will go from there, but some of my questions pertain to the FRC as well. The schematic I want would be of the FRC. You might be right, I think I will be better off posting that in a new thread. Moderators: please don't kill me for posting kind-of the same thing in two threads.
Unread 24-01-2006, 09:00
None #0116
This is from my personal experience with the code and camera on the mini-RC. There are other (and probably better) ways to do this, but I know it works. The code worked perfectly out of the box once I got the camera set up. The TTL convert has four inputs, but the mini-RC only has three pins on the TTL port. The fourth pin, which is missing, is for +5V to power the TTL converter board. I had to cut one end off of a PWM cable, solder a header pin to the red wire, and plug that into the open slot on the TTL board. Cut about 1" off of the black and white wires to give yourself some room to work. You could also use a piece of resister lead for the pin if you don't have any header pins. Heat shrink the solder joint so that no exposed metal pokes out when you plug it into the TTL converter board.
1) Connect a PWM cable from the TTL port on the mini-RC to the inputs on the TTL converter board so that the black lead matches B on the board.
2) Connect your hacked cable with the power pin to a PWM output or digital/analog input. The red pin will pull +5V from the port.
3) Connect the pin on the red cable to TTL converter board. It will be the open slot opposite the one marked B.
4) Connect a PWM cable from the TTL converter to the camera's RS232 input.
Unread 24-01-2006, 14:55
lkdjm's Avatar
AKA: David Mazza
Thanks! That's exactly what I needed to know. Now I can pass that on to my electronics guy!
Unread 19-01-2006, 18:59
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
We had to make some minor changes to the default 'bells and whistles' code to make it work with the EDU-RC controller, but it seems to work. If you want a copy of this let me know, and I can supply them. Another one of our programming team made the mods, or I'd post exactly what we had to change in this thread.
One issue I didn't see in this forum involves using the Labview application with the CMUCam2. Bear with me while I describe the problem before replying, because in general it DOES work.
After a few (more than 2, less than 10) frame grabs, the application shows the progress bar going from 0 to 100%, pausing momentarily at 100%, not displaying the frame that was grabbed in the window, then after some amount of time (more than 30 seconds, less than 5 minutes) it re-tries getting the image and the progress bar goes from 0 to 100% as before. Once the application is in this state, the only solution is to close LabView, open the project and run it again. This typically fixes it, and we can grab a few more frames before it crops up again. As one could guess, this makes camera calibration/focusing a very trying task.
Relevant information:
EduRC from 2005
Freshly charged backup battery providing prime power for EduRC and cam
Laptop with REAL serial port (none of that USB nonsense)
Original CMUCam2 code (not the EduRC version, we started this before seeing it was available) with minor mods to build cleanly for EduRC2005 instead of FRC2006.
At this point, we only need to do some minor tweaking of camera values to consider it fully 'calibrated' so it's quickly becoming a moot point, but I'm hoping this info might help to make the Labview app more stable. It's certainly a grand improvement over the original Java version from last year.
Cheers,
-Eric
  #15   Spotlight this post!
Unread 19-01-2006, 19:04
It would be great if you can post it!
And thank you everyone for the quick response!
2006 CMUcam2 Code Kevin Watson Programming 81 10-02-2007 20:17
CMUCam2 code (FRC and EDU?) Amber Programming 0 15-02-2005 22:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
heres the code. y this not working omega Programming 16 31-03-2004 15:18
