Go to Post If I was making this I would want to not have to use anything smaller than a 3/16" end mill, but 1/8" would be acceptable. Anything smaller and I'd tell the designer to go play in traffic. - Cory [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 19-01-2006, 17:14
JJMax7 JJMax7 is offline
None #0918 (Circuit Chargers)
Team Role: Driver
JJMax7 is an unknown quantity at this point
Send a message via AIM to JJMax7
New Gear Tooth Sensor- Connection
My team has decided to use the gear tooth sensors this year. We installed the new ones into the transmission plates, but I don't know where to plug in the PWM. There are two sets of holes marked like a PWM (Black, Red, and White) Are these where we plug in the PWMs? If so which set, or do we use both? And if not how do we connect the sensors to the Robot Controller?
Thanks in advance for the help.
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
gears Michael Leicht Inventor 12 16-09-2004 10:52
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
