Go to Post shhhh...our robot is in a bag now, it won't hurt anyone till the milwaukee wisconsin regional. hopefully it won't be fiesty. don't wake it. - Toatekua [more]
  #16   Spotlight this post!
Unread 19-01-2006, 21:35
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
Re: Blocking Shooting Robots
Originally Posted by BradL
Mount a large fan on the top of your robot and blow there balls out of the way. Just a thought, probably won't work.
Funny you should mention that cause our team experimented with idea and came to the conclusion that the amount of power you need to generate the air to blow the ball away would cause your battery to run dry in a VERY short amount of time. But on the plus side, by blowing air upwards, you give your bot extra traction so if you find a good spot where you can shoot, collect, and block this would be a sweet idea (and amusing to watch). I like the way you think
BEHOLD, THE LEAF BLOWER OF DOOM!!!
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
  #17   Spotlight this post!
pwilczynski's Avatar
pwilczynski pwilczynski is offline
FRC #0236 (Techno Ticks)
Rookie Year: 1993
pwilczynski is on a distinguished road
Suring the brainstorming, our team came up with making a sort of 'fan' that you could sit under the goals with and 'blow the current up and knock balls away. Power consumption would probably be very high, and it would take a really strong fan. it was a cool thought; our robot could have been The TORNADO!!
  #18   Spotlight this post!
Unread 19-01-2006, 22:25
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work
just keep your human player away from the event horizon.
  #19   Spotlight this post!
Unread 19-01-2006, 22:34
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Keep in mind the bumper rules this year.
Defense and contact are important and entertaining, but don't hit high or you risk penalty!
  #20   Spotlight this post!
Unread 19-01-2006, 22:42
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: another question
Originally Posted by KenWittlief
if you plan to defend your goals by blocking, that will be interesting. Your bot will have to be able to take a 12M/S shot to the head, repeatedly, and stay on its feet.
With the momentum of a poof ball at 12 m/s it's hardly a nudge. Although robots should always be protected from field components and other bots.
  #21   Spotlight this post!
Unread 19-01-2006, 23:24
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
Make an extending PVC pipe addition on both sides of a robot at exactly 5 feet. Have cloth connecting the two, but make it have slack so you can get around the flag. then you just keep following the robot with the cloth over it. It will force the ball back into the shooter, and piss off a team pretty bad. I decided against it for GP.
  #22   Spotlight this post!
Unread 19-01-2006, 23:34
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
Team Role: Coach
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
With the slack you suggest, the cloth between the two poles would droop down below 5', and when you tried to push it over another robot the fabric would probably get caught up on the front of the other robot.
But seriously, if you have enough time sitting in front of this 'bot that is trying to shoot to extend a drapery over it, you probably have time to find something else to do to foul their aim before they fire a ball.
EDIT: Hadn't meant to post yet
Oh, maybe I shouldn't have pushed that...
  #23   Spotlight this post!
Unread 21-01-2006, 00:07
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
We did some tests with an electric leaf-blower and found that the only reliable way to knock a ball away with it was to track the ball...something taht would be quite hard. Even without the power restrictions we determined it wasn't feasible.
  #24   Spotlight this post!
Unread 21-01-2006, 01:38
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
ACTUALLY thats not a bad idea... *long as your under hight requirements* you could mount a fan on your robot. I'm thinking and i just did the math, that if you had a 22" fan blade going around 1500 RPM's you could blow away the 9" foam ball. you could use 1 CIM * i think thats there RPM's i haven't checked. if so.. you would only need to turn it on when they shoot other wise you can push balls in your corner or go on D. You need a tyranny with a really high recto so you get high speed in a matter of secs. AND the battery draw shouldn't be much since 2 Min's and only for a matter of sec's.. BUT don't listen to me i only build what my team says to *referring to last year because sadly I'm not on a team this one.*
Just my .02 cents
~Doug
  #25   Spotlight this post!
Unread 21-01-2006, 08:32
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
I believe yu have all missed the best way!! shoot their ball out of the sky! (patriot missile style!)
the balls in our kit came with one half green. you could use the cmu_cam to track this green, plot the tracjectory, aim ahead of the ball and shoot it out like a digital nintendo duck!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
  #26   Spotlight this post!
Unread 21-01-2006, 09:35
FTtyler's Avatar
FTtyler FTtyler is offline
FRC #1561 (Purple Ducks)
FTtyler is an unknown quantity at this point
Originally Posted by i_am_Doug
Could some one "enlighten" me on the flag thing?
The flag can not be over your 5 ft limit.
  #27   Spotlight this post!
Unread 21-01-2006, 10:55
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
This is incorrect. The flag can not exceed 6 ft. If your robot is 5ft, then it MUST be 12" taller.
Originally Posted by <R13>
Robots must use one of the two colored bicycle flags provided at the event queuing location to display their alliance color (red or blue). Each robot must include a 12 inch long, 1/2” ID PVC tube, capped at the bottom, permanently mounted on the robot such that when a 3 foot long, 1/4 inch diameter flagpole is inserted the top of the flagpole is no higher than 6 feet from the ground and the top of the flagpole is at least 12 inches higher than any other point on the robot (+/- 1/2 inch). The flagpole must be mounted such that it starts the match, and remains, approximately vertical. The flagpole receptacle must be statically mounted, and not articulated or actuated.
Wetzel
Viva Olancho!
Fully autonomous robots? Mike Programming 29 18-01-2006 21:37
Robots compete in first match (FitN) Clark Gilbert FIRST In the News... 0 24-03-2004 18:11
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
How are robots lowered? Yan Wang Rules/Strategy 5 22-02-2004 22:10
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
