| View Poll Results: Are you going to get on the ramp at the end of the round? | |||
| Yes |
71 | 76.34% |
| No |
9 | 9.68% |
| Not tellin |
13 | 13.98% |
| Voters: 93. You may not vote on this poll | |||
Ramp or no ramp
Hey I was just seeing if teams thought how hard and if it is important to get up on the ramp at the end of the match. If so can you?
-John |
Re: Ramp or no ramp
Team 1345 made a prototype chassis which has been posted on the forum few days ago. That chassis goes up the ramp very easily. So yes, it is worth it and you can do it fairly easily. Also, I was in team 179's shop the other day and their 2k5 robot rides up the ramp very easily. The clearance for swampy 2k5 was 2 1/2". Keep in mind the ramp was made out of plywood.
... question is how much difference is it going to make with the diamond plate and the top of the platform? |
Re: Ramp or no ramp
Lots. The grip is just not there. I was surprised when we tried it the first time and noticed the slip factor. When you build, you will see. |
Re: Ramp or no ramp
Most qualification matches will be decided by the ramp. You can quote me on that one.
Re: Ramp or no ramp
I think we will see a lot of robots tipping over, either fighting to get on the platform, or just with a high CG that doesn't accomodate that 30º ramp.
Re: Ramp or no ramp
The Ramp will be important. I'd rather have a dump truck robot with a high powered drive train, and the ability to make it up the ramp, than one with omni wheels that can shoot 3 pointers and not make it up the ramp.
Re: Ramp or no ramp
I believe that it will be important to get up the ramp, but also, teams can help each other up. I remember in the animation the blue shovel bot pushed the other two up the ramp to get all three 'bots on. I think if a team had a good bot to go up the ramp he could easily push an omniwheel bot up
Re: Ramp or no ramp
Re: Ramp or no ramp
Diamond plate is fairly slick if your traction doesn't grip the diamonds. |
#10
Re: Ramp or No Ramp
Our robot cannot do the ramp. We built the robot without caring about the ramp, and tested to see if we could. Our chains hang too low and hit the corners of the ramp as we go up, plus our robot is too tall and falls over on the incline (at least at a stand still).
We believe the ramp will be unimportant to us though. If there are not 2 robots already on your platform, it is worth 5 points. Two balls shot in the center at the end is worth more than this. If there are 2 already on yours, you need to now make up 15 points, but this can be done by shooting in 5 balls, OR by shooting in a few balls and pushing one of your opponents at the end so they cannot get on the ramp. Taking away 5 or 15 points from your opponents is the same as scoring it for you, plus you get whatever you shoot in beforehand. |
#11
Re: Ramp or no ramp
Our robot will be able to make it up the ramp even with the omni wheels in the front. Our back tires will have enough grip to push up the ramp and we've incorporated brakes to the wheels to make sure we don't slide back down at the end of the match.
#12
Re: Ramp or no ramp
brakes are a good idea. I was thinking about that.
We will aslo be able to make the ramp. |
#13
Re: Ramp or no ramp
Re: Ramp or no ramp
right...brakes, I have to say it's a good idea, thanks for it. and btw, I agree high CG bots will lose at the ramp, but I think the ramp will play a big part just not as big as lil'lavery made it out to be. ![]() |
#15
Re: Ramp or no ramp
And on the subject of brakes... Is it legal for robot's to become temporarily airborne? It is a very freaky experience watching an AM transmission in fast speed making it's way towards your alliance station, with a jump between you and it. Last edited by Ian Curtis : 19-01-2006 at 22:21. |
| Holonomic drive and ramp | robotaddict | Technical Discussion | 11 | 13-01-2006 16:57 |
| Ramp and Platform model problem. | Jay Trzaskos | Inventor | 1 | 08-01-2006 02:13 |
| Ramp Riot 2004: Call for Comments | OZ_341 | Off-Season Events | 4 | 28-11-2004 14:53 |
| Pulling robot off ramp legal? | archiver | 2000 | 2 | 24-06-2002 00:14 |
| Technical question about ramp balancing | archiver | 2001 | 5 | 23-06-2002 22:29 |
