Camera never finds target, stays at "Searching..."
We finally got our robot/camera all set up tonight. I managed to calibrate the camera using LabVIEW, and it tracks consistently through that. However, when I load Kevin's code onto the RC it stays in the "Searching..." mode. I edited all the options in tracking.h, DEBUG goes through all 18 states and then into searching.
Any idea on whats wrong? Thanks, Mike EDIT: I would try the serial port diagnostics program, but our school doesn't give us wireless access, so I can't get it on my programming laptop ![]() Last edited by Mike : 19-01-2006 at 19:26. |
Re: Camera never finds target, stays at "Searching..."
We got the same error.
Solution: give up. |
try using camera_s or whatever (the simplified version) we had the same problem but the no bells and wistles version solved our problem
I had that problem.. the solution was to roll back to the default values that came with the code. From there, once it works, you can slowly start tweaking things one at a time to make it work a little better.
Go try the default code with no changes. |
I wonder if the camera would work better if they made it track an infrared light source and the put a visible light filter over the lens...
An offseason project, I guess. |
Thanks for the help...
We are using the simplified version. Sadly, I have to work tomorrow night (boo!) so I won't be able to go into robotics and try out the rolling back idea. I might get access on Saturday, so I'll post then if/when I have a problem. Thats probably a good idea in theory Greg, but I couldn't imagine how much IR interference there would be. I wasn't around in ye olden days (04) to program with the IR beacons, but from what I've heard such small things as the auto-focus on a camera (which uses IR to sense the distance) can cause interference. |
-Kevin |
-Kevin |
So what's the point of the LabVIEW program? |
#11
If you change the config to everything that labview works, stuff stops working. I think I changed the stuff for Track_Color a little, and increased NF_DEFAULT to 3. Past that, not much I need to do |
#12
Our team used LabVIEW to come up with the correct calibration values just like you did. Similarly, when we went to use the bells and whistles code on the robot (the EduRC actually) it seemed to lose track of what we had told it. The key is that the camera code by default puts the camera BACK into RGB even if you did your calibration values. This isn't a simple switch in camera.h, turns out it's actually a bit in the COMA register (the bit ID escapes me at the moment but it is documented). Once we figured that out, we had our EduRC bot with the bells and whistles code following our GLOD* with no more issues, based on the 'highly calibrated' Labview values. -Eric *GLOD=Green Light Of Doom |
| How To Use the Google Camera | generalbrando | Kit & Additional Hardware | 2 | 07-02-2006 16:00 |
| Camera pointing error? | Craig Putnam | Programming | 14 | 21-01-2006 02:52 |
| For anyone who doesn't get the camera code..... | Jake M | Programming | 8 | 16-01-2006 18:56 |
| LabVIEW - CMUcam finds target but cant track | bear24rw | Programming | 6 | 13-01-2006 21:43 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
