Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 19-01-2006, 19:54
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
first did a good rules job this year
i must say first did a great jod with the rules this year. Usally by this point we have 14 major rules problems but as of yet nothing. I give first an A for the season opener i am sure that this report card will look good by the end of the season.
shaun
Unread 19-01-2006, 19:59
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: first did a good rules job this year
I agree--3 updates, and none of them had any major changes that I could find. Let's keep it up. (What would really surprise me is if there were NO rule changes in Section 4 at all.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-01-2006, 21:07
Frenchie's Avatar
Frenchie Frenchie is offline
AKA: François Baldassari
FRC #0469 (Las Guerrillas)
Frenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to beholdFrenchie is a splendid one to behold
well, on the other hand it is the first time FIRST tells us how to do something specifically (bumpers), which is somewhat frustrating.
Unread 19-01-2006, 22:03
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
i'm not sure, but I assume you could put your own bumpers on, but they just have to fit w/in the starting box and be included in the weight limit...
Unread 19-01-2006, 22:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I agree on the rules. There is a lot less ambiguity than before.
Unread 19-01-2006, 22:52
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
First bullet in the bumper rules section:
<R35> Bumpers must be designed as shown in Figure 5-1.
So I wouldn't think about desiging your own bumpers if you want the advantage of weight and size(if size is an advantage).
Unread 19-01-2006, 23:05
Nuttyman54's Avatar
Mentor, Tactician
Yes, i didn't make my point clear: FIRST isn't restricting the design any more than in past years regarding bumpers, but are instead providing more options
Unread 20-01-2006, 09:51
arabsponsor arabsponsor is offline
AKA: Barbara Boyles
FRC #0538 (Dragonslayers)
Team Role: Teacher
arabsponsor will become famous soon enough
The way our team understands the bumpers, is you must use FIRST's design or forgo any bumpers at all. Are we wrong?
Unread 20-01-2006, 10:15
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
You are wrong. If you wish to design your own bumper you may do it. The bumper however must be within your 28x38 dimension and counted in your 120 lb limit. If you choose FIRST bumpers then you get added size and extra weight without breaking the rules.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 20-01-2006, 10:17
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I believe you are wrong. Bumpers that follow the FIRST design are not counted against the robot weight or size limits. I don't see any rules which forbid bumpers which are part of the robot as weighed and measured at inspection.
(There are rules which constrain bumpers. For instance, contact surfaces must be near vertical, and one may not use "wedges", which seem to be defined in a way which includes articulated bumpers that lift an opponent.)
Unread 20-01-2006, 11:01
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Team Role: Coach
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
they did about the defensive side where you only get the bumper zone but other than that some of them are confusing comparing to previous years.
Unread 20-01-2006, 17:27
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
I give the Game Creators a A all over. There have been no major changes...yet. There are so many avenues for strategy that its hard, at times, to grasp it all. So to those who did a good job, we salute you.
You write the forum rules Ken Leung CD Forum Support 8 17-01-2005 11:18
Uniform rules and enforcers? Ben Mitchell General Forum 31 12-01-2005 20:55
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
why why why...? archiver 2001 34 23-06-2002 22:13
