Go to Post Attitudes in one part of life tend to carry over to others. - Wetzel [more]
Unread 19-01-2006, 22:31
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
Loading Help...
Hi,
I have the camera set up with the RC, everything is hooked up fine, except I need to put a backup battery on there. (until then, running off the 5v analog is working fine for LabVIEW testing)
I have a "mini" board setup to try and program, only problem is no program runs when I load it onto the board. When I load the camera program nothing happens on the terminal window, when I load serial diag, nothing happens. Only thing that appears is the IFI when I reset the RC. Please help, I've had so many hardware problems, I haven't even touched the code yet !
www.sabrerobotics.com
Unread 21-01-2006, 00:12
Denz's Avatar
Re: Loading Help...
Ok, I attached the backup battery, the servos and cam have power and everything seems fine, except the code is doing nothing. Infact, no code that I tried to load seems to do anything. Any suggestions at all? PLEASE! I'm really stumed on this.
I can load everything on the board, all the lights are running, just nothing happens in terminal window, or on the bot. Do I need to attach the Operator Interface for codes to work? Any suggestions would be greatly appreciated!
Thanks in advance!
Unread 21-01-2006, 08:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Loading Help...
Yes.
Unread 21-01-2006, 11:46
Denz's Avatar
Re: Loading Help...
I guess I should do that then. Thanks alot. Too bad I have to wait until Monday, because the school is locked up. But I'm happy to have found what the problem probably is! Thanks again!
auto vs. manual loading zone, which one? Liz C Rules/Strategy 44 29-04-2005 07:04
Tetra auto loading zone clarification... Gary C Rules/Strategy 21 24-01-2005 13:03
Blocking opponent's loading zone SoccerNerd36 Rules/Strategy 6 17-01-2005 17:27
Pushing robots out of loading zone jgannon Rules/Strategy 24 09-01-2005 18:01
Automated Loader without being in loading zone geeknerd99 Rules/Strategy 3 08-01-2005 21:57
