Go to Post Having 75% of the drive train without direct connection to the transmission would make me a bit queasy, but then again, I'm not Winnovative. - Taylor [more]
Unread 20-01-2006, 16:19
BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
CMU cam and drive wheels
Hey!-
I'm a really novice programmer and I have no idea how to deal with this problem. We downloaded Kevin's code and have been able to track the light, but we want to put the drive motors on pwm01 and pwm02. We changed them in the program where it defines them, but now the drive motors will not work. Is there something in the program that negates how user_routines.c maps the port 1 joystick to pwm01?
Any help that you can give would be much appreciated!
Unread 20-01-2006, 16:31
VideoMan053's Avatar
VideoMan053 VideoMan053 is offline
Computer Freak
AKA: Dan J.
FRC #0063 (Red Barons)
VideoMan053 is an unknown quantity at this point
Send a message via AIM to VideoMan053
Re: CMU cam and drive wheels
yes, in the camera code, the whole routine that maps joysticks to pwm ports is commented out ( // and /* */)
Code:
//  ***  IFI Code Starts Here***
//  static unsigned char i;
//  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
//  Default_Routine();  /* Optional.  See below. */
//  /* Add your own code here. (a printf will not be displayed when connected to the breaker panel unless a Y cable is used) */
you can see that the function calling the Default_Routine (joystick mapping) has been commented out...I believe this is for safety, i.e. human drive can't drive the robot while the robots driving itself...
You could rememdy the situation by letting the camera drive and align itself, turn the camera off, and then begin calling this function, but I'm not sure exactly how that could be done yet.
GET OVER IT! ~ not the most useful words in competitions, but some of the most useful in life!
My Jobs: Programming
Unread 21-01-2006, 16:01
Thanks a bunch! I really apprciate that!
Square Wheels? mechanicalbrain Technical Discussion 11 08-01-2006 17:34
