System time
Right now I have worked a long time on customizing a timer found in Kevin's interrupt code to run indefinatly. I was wondering if anyone was able to get a system timer that runs fast enough to use for speed but slow enough so I can get and it doesn't get too big to handle?
/*I used a 1:1 pre-scalar for an interrupt and the controller freaked out, overflowing a 16 bit value every 26.6 ms*/ Last edited by Joohoo : 20-01-2006 at 21:17. |
Re: System time
Use a 32 bit timer :-)
In other words, when your 16 bit timer gets to big, add it to a 32 bit variable and reset it. If 16 bits overflows in 26.6ms, 17 bits will overflow in 53.2ms, and so on. 32 bits shouldn't overflow for 29 minutes. |
| Students, what is your fantasy education system? | Ken Leung | General Forum | 28 | 04-01-2006 09:20 |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
| How long should production time be??? | archiver | 1999 | 4 | 23-06-2002 23:16 |
| need help with time zone! | Ken Leung | General Forum | 6 | 25-06-2001 12:44 |
