Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 20-01-2006, 23:13
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Question about Solenoid and default code
pneumatic system:
air pump-Is it relay #8 and digital in/out #18?
double solenoid-Is it any relay?
Unread 20-01-2006, 23:15
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: Which default pins for the following??
You can connect them to any number you would like and set it accordingly in the code. That's just the default.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 21-01-2006, 01:27
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
I know this is the wrong topic but how? I checked the code and cant see where?
Unread 21-01-2006, 17:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
In the (1-04-2006) FrcCode project, the user_routines.c file has the following line in the Default_Routine() function:
Code:
  relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
It's easily overlooked in the midst of all the other relay and pwm control code.
Unread 21-01-2006, 18:21
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
Thanks,
We are like rookies again since we have a totally new group of students and engineers. Our veteran mentors are officially "retired," and we already asked them "too" many questions.
Aloha!!
Default mapping relay questions Jared Stofflett Programming 1 25-02-2004 19:06
