White Paper Discuss: Measuring Distance with Analog Potentiometers
Thread created automatically to discuss a document in the White Papers.
Measuring Distance with Analog Potentiometers by Daniel |
Re: White Paper Discuss: Measuring Distance with Analog Potentiometers
What kind of potentiometer are you specifically referring to? With all the pots I've encountered, they have a mechanical stop that prevents them from turning past about 270 degrees. I sincerely hope you're not suggesting taking apart a potentiometer and removing the mechanical stop.
I've implemented a LabVIEW library for doing this with the new control system.
See here: http://forums.usfirst.org/showthread.php?t=10546 By the way, even if you don't use continuous turn potentiometers, everyone should look at the method Daniel uses for a cheap flexible shaft coupling. |
| White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team | Jessica Boucher | Extra Discussion | 1 | 20-11-2005 20:01 |
| White Paper Discuss: Sponsor Care Presentation | Chris Fultz | Extra Discussion | 0 | 25-04-2005 12:51 |
| White Paper Discuss: FIRST Sponsorship = Excellent Corporate Strategy | Chris Fultz | Extra Discussion | 0 | 12-04-2005 20:23 |
| White Paper Discuss: Joystick Sensitivity Demystified - Version 2 | marccenter | Extra Discussion | 0 | 28-02-2005 16:54 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
