Go to Post After all, it's not where you are but the people you're with that make it worth while. - RoboJedi75 [more]
Unread 21-01-2006, 00:12
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Strength difference between aluminum
I want to know if there is a significant difference between 3/4" by .125" thick square aluminum tubing, and 1" by .125" square aluminum tubing. I am planning to use it in a welded frame.
Unread 21-01-2006, 01:30
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: Strength difference between aluminum
The simple answer, of course, is that yes there is a strength difference. How much of a strength difference, and whether it is significant, depends on how you design your structure and how the load is applied to it.
To be completely technical, strength refers to either the Ultimate Tensile Strength (where the material breaks) or Yield Strength (where the material deforms and does not return to it's initial shape). When you bend a paperclip into a new shape you have exceeded the yield strength (also known as yield stress) but not the ultimate tensile strength (or UTS).
What you are most likely intersted in for your robot, however is not yield stress, or UTS, but rather stiffness... how much the structure will flex under a given load. Rather than go into great detail, I'll suggest you look at the manual for West Point Bridge Designer (a great program and a great contest) at http://bridgecontest.usma.edu/
Suffice it to say, however, that the 1" tubing will be significantly more stiff than the 3/4". In most cases, however, it is not likely to be the tubing that fails... you are far more likely to get failure at a poorly designed joint or corner. Don't be afraid to ask the person doing your welding if they think the joints are strong enough. Someone with the skill to make a good weld in aluminum tubing has seen enough joints to know where a little extra gusseting is needed.
For the record, our robot will likely use mostly 3/4" by .062 tubing in the superstructure on top of a KOP chassis.
Good luck, and DO check out the West Point Bridge Designer site. Steve Ressler at West Point has done a fabulous job of explaining structures and materials in a way that is high-school student friendly.
Jason
Unread 21-01-2006, 01:40
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Strength difference between aluminum
To answer this question, the moment of inertia is basically a number you can use to compare shapes' strengths relative to one another.
See attached 'secret spreadsheet' snapshot.
It shows that 1" x 1/8" box will be about 2.5 as strong as 3/4" x 1/8" box. This surprises most who aren't familiar with how this calculation is performed.
If your question is, "Is there really that big of a difference?" The answer is yes.
Also note, that 1" x 1/16" is about 50% stronger than 3/4" x 1/8".
Something to chew on.
Matt
Unread 21-01-2006, 10:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
If you have the full install of Inventor 10, you should have something called "Design Accelerator" which has lots of useful calculators and formulas for just this sort of thing.
bolting square aluminum without crushing walls greencactus3 Technical Discussion 11 20-01-2006 16:58
A funny story involving 80/20 Aluminum! Rombus Chit-Chat 1 12-04-2005 00:44
Using Extruded Aluminum to telescope. LGuY Technical Discussion 21 07-02-2005 12:43
Box Aluminum Extrusion Strength generalbrando Kit & Additional Hardware 9 19-01-2005 16:46
Difference in aluminum archiver 2001 1 23-06-2002 23:49
