Go to Post If Amanda is 'old', I am beginning to feel like a fossil.... - Chris Fultz [more]
Unread 10-04-2007, 11:02
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
Re: Servo Values to Degrees... How?
Originally Posted by #root: View Post
Hey, I've been having a problem setting the correct degrees to a variable, even though it prints to the terminal correctly.
pan_angle = (((int)PAN_SERVO - 124) * 65)/124;
tilt_angle = (((int)TILT_SERVO - 144) * 25)/50;
I have tried making these variables ints, floats, and doubles (they are global static declared in user_routines.h, set in terminal.c, and used in user_routines_fast.c). Would it help if I cast pan_angle and tilt_angle as ints or changed 124 to 124.0? Maybe if I did
(int) pan_angle = (int) (((int)PAN_SERVO - 124) * 0.5242);
Any help would be appreciated. Thanks!
Be careful when declaring variables. They should not be declared in the header file. The header is used in several places, which can cause copies of variables to occur.
In the user.c you should have;
Code:
int   pan_angle = 0 ;
In user.h you should have;
Code:
extern int   pan_angle ;
Then user_fast.c will see the external variable when the header is read.
Jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 11-04-2007, 02:03
#root:'s Avatar
#root: #root: is offline
FRC #1622 (Team Spyder)
#root: is an unknown quantity at this point
I tried to declare it as an extern, but I was having trouble using and then accessing the variable in both terminal.c and user_routines_fast.c.
Well, hopefully I can figure it out by the time the competition starts!
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Values DanDon Motors 8 14-02-2005 15:49
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
