Go to Post Do whatever you must to survive within the rules, but please stay within the rules. - Kevin Sevcik [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 21-01-2006, 14:40
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
FP motor gear DP & PA, source ?
Does anyone know the specs of the stock metal gear that is on the FP (not cim) motor ?
What Diametral Pitch ?
What Pressure Angle ?
What shaft diameter ?
Anyone know of suppliers that sell gears that can mate to it ?
I am presuming the thin plastic gear in the black transmission won't survive long in a First environment ?
Anyone know if noisy planetary gear-case could be less efficient than a standard 2 gear transmission ?
Unread 21-01-2006, 15:05
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: FP motor gear DP & PA, source ?
I can answer some questions but not others.
Historically, FP uses gears on their motors that are 32DP, 20 Deg. Pressure Angle. They do not usually enlarge the pinion. It is essentially a standard gear made to the slightly modifed standards for plastic gears -- for anything we do in FIRST, you can pretend it is a standard gear.
The upshot of this is that you can verify the DP data by just measuring the OD of the gear and dividing (Nteeth +2) by the OD.
For example if the OD is .563 and the gear has 16 teeth, you would get a DP of 18/.563 = 31.97 or 32DP.
As to the planetary gear effeciency vs. straight spur gears, spur gears will almost always be more effecient. I typically estimate spur gears to be 95% effecient per stage and planetary gears (with ratios less than 5.5 to 1) to be 85% effecient per stage.
If you get two stages the planatary gears would give you 72% eff. while spur gears would give you 90%.
As to the shaft diameter, it is the same as the Mabuchi motor. From the Mabuchi print the shaft diameter is 3.17mm +.007/-.005 = (.125"+.0000"/-.0005").
As to surviving a FIRST application with the plastic gears, this is done by many teams. It depends on the application. Big arms or main drive motors would make me nervous. Pitching machine wheels and auxilary ball collector belts wouldn't give me heartburn at all.
A word of caution about Nteeth. There has been variation from kit to kit in the past over the number of gear teeth on the pinions with some getting N and others getting N+1 or N-1 or N+2 or N-2. If you count the number of teeth and share them with us here, please provide the part number of the motor as well so we can sort things out.
Thanks.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 21-01-2006, 16:41
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Our F-P is a 9012, and it has a 32 pitch, 19 tooth pinion on it.
Ken
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Open Source CAD Jeff Waegelin Inventor 5 16-12-2004 12:51
[FVG]: Source Code SilverStar FIRST-related Organizations 5 24-08-2004 14:28
Virtual Match Viewer SilverStar Programming 6 19-04-2004 16:19
Open source Jeff_Rice Programming 16 25-03-2003 23:40
