Go to Post My contention is that there is not a whit of difference between noting that a change like that has to be made, and making the change. - Kris Verdeyen [more]
Unread 21-01-2006, 16:16
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Globe motor to spike controller
Can the globe motors be hooked up to a spike speed controller? That's all, Thanks
Unread 21-01-2006, 16:47
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Globe motor to spike controller
Yes, the only motors not allowed on spikes are the Cim's both sizes and the Fisher Prices . The converse that If you want to run all your motors on Victors you are allowed to. The section of the manual that relates is the robot section.
Unread 21-01-2006, 21:50
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
While i can not find a rule currently saying you can't use the globe motors on a spike relay, i would not suggest it. FIRST recommends here that you use a victor for a globe, and i would suggest the use of a victor too. A spike relay gives you an on or off state while the victor motor controllers gives you a variable control of the motor and will also let you back up the motor with a 20 amp circuit breaker.
-Michael Dessingue
Unread 21-01-2006, 21:55
BrianBSL BrianBSL is offline
FRC #0190
Rookie Year: 2000
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Originally Posted by dez250
While i can not find a rule currently saying you can't use the globe motors on a spike relay, i would not suggest it. FIRST recommends here that you use a victor for a globe, and i would suggest the use of a victor too. A spike relay gives you an on or off state while the victor motor controllers gives you a variable control of the motor and will also let you back up the motor with a 30 amp circuit breaker.
Why?
If we look at the spec sheet - http://www2.usfirst.org/2005comp/Specs/Globe_Motor.pdf, it shows a stall current of only 22A. If you look at the snap action circuit breaker spec sheet, it shows it needs 10 full seconds at the circuit breaker rating to blow. Therefore, I see no problem with running the Globe on a 20A breaker, and using a spike, if you don't need speed control. This could save a team nearly $100, if they didn't have to buy another speed controller.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 21-01-2006, 22:02
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
I agree. Especially if you replace the fuse in the SPIKE with an auto-reset, which is legal. You're probably not going to stall the motor for very long, and if you do, you'll burn it before you hurt the spike, I would think. The only thing your team needs to decide is if they need the variable control of a victor. If not, make it easy in yourselves, right?
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 21-01-2006, 22:27
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
By <R61> this is specifically legal for the compressor; however, it is implicit that for any other device, this constitutes an illegal modification to the Spike (since it is specifically permitted as a modification, in one exceptional case only).
Also, if we interpret 5.3.9.1 in a consistent sense, to "protect" a circuit refers to the presence of an appropriate breaker in the panel, and not (necessarily) in the Spike itself, if present. (I say consistent, because the same phrasing is used to refer to Victors, which lack an integral fuse.)
So while that section may have been the source of the confusion, it appears that FIRST intends that the Spike fuses remain as installed, and an extra breaker be used to protect that circuit in a redundant fashion. From an electrical standpoint, I don't really see why this is necessary, or even desirable—why mandate the use of two devices of the same current rating to protect a circuit, when one circuit breaker would be simpler, or two circuit breakers would be more useful (albeit exceptionally redundant)? Even a manually-resettable circuit breaker ought to be allowed (but isn't) in place of the fuse. This rule seems to be one that keeps appearing in this form, and I'm not really sure why.
Unread 21-01-2006, 22:29
FRC #0190
Rookie Year: 2000
I believe this is only legal on the spike running the compressor -
<R61> The control system is provided to allow wireless control of the robots. The Operator Interface, Robot
Controller, Speed Controllers, Relay Modules, Radio Modems, Batteries, Battery Charger, AC Adapter, and
9-pin cables may not be tampered with, modified, or adjusted in any way, (tampering includes drilling,
cutting, machining, gluing, rewiring, etc.) with the following exceptions:
• The dip switches on the Operator Interface may be set as appropriate.
• The user programmable code in the Robot Controller may be customized.
© FIRST 2006 FIRST Robotics Competition Manual, Section 5 – The Robot, Rev C Page 18 of 30
• The Speed Controllers may be calibrated as described in owner's manuals.
• The fuse on the Spike relay for the Air Compressor may be replaced with a 20 Amp Snap-Action circuit
breaker.
But if you have to worry about the globe blowing the fuse, then you have a mechanical design problem (stalling the motor).
Unread 21-01-2006, 22:40
FRC #0306 (CRT)
Huh, I could've sworn that it was on any SPIKE. It doesn't make any sense to use one on the compressor. It wouldn't seem that the compressor would ever draw that much current.
-Sir Francis Bacon
-Albert Einstein
Unread 21-01-2006, 23:01
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Strange. I thought the same thing, but the 2006 AND 2005 rules clearly state this. Hmmm...
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 21-01-2006, 23:13
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
In the past teams had problems with the 20A fuse in the spike for the compressor blowing. When the compressor kicks on with an almost full tank it is near stall current, and repeated long enough a fuse will eventually fatigue and blow.
Allowing breakers in the spike for the compressor is a compromise, to keep teams from going through matches with no air pressure. Other motors that you use, driven by the spikes, should never be near stall current.
Unread 22-01-2006, 08:32
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
You are missing the point on using circuit breakers on the robot electrical vs. the protection provided by a fuse in the Spike. The circuit breakers are chosen with minimum rating for protecting the wiring. (See R82, 83, 84) A 20 amp circuit breaker will keep a #18 from setting itself on fire in the event of a short. The 20 amp fuse in the Spike protects the contacts in the relay from destruction but does not protect the wiring since it is at the end of a wire run. Since the compressor draws more than 20 amps during start but has a run current much lower, IFI and First have determined that the fuse may be replaced by an auto reset circuit breaker for the compressor control only.
The globe motor can be used with a Spike with the understanding that you have no speed control. Only one motor per Spike, please.
All Chalupas (large and small) and all FP motors must be connected to Victors per R87.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 22-01-2006, 11:22
Rookie Year: 1999
Originally Posted by Al Skierkiewicz
Guys,
Bearing in mind that this is (of course) totally illegal for FIRST purposes, what would be the effect of placing a jumper (or, alternatively a 100 A fuse) on the Spike, and a 20 A breaker in the panel, as usual? For a reasonable length of wire, wouldn't the 20 A also lend sufficient protection to the Spike, or is the Spike so sensitive to a current spike ( ) that it requires protection very close to the source of the fault? (If that fuse doesn't blow very quickly indeed, I don't see how that could be the case, though.)
Current reversed on compressor spike controller scottish144 General Forum 20 05-09-2005 07:33
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
