Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Unread 21-01-2006, 16:41
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
default camera code edit
Does the default code for the camera (MPLab) have some sort of setting or special function that prevents programmers from adding their own code? The camera code runs perfectly (as far as we can tell anyway), but our code that we added to the file under Default_Routine (which worked on other default codes) doesn't work now. Is there something we are supposed to change or do?
Unread 21-01-2006, 17:02
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: default camera code edit
Make sure that you call the Default_Routine from the Process_Data_From_Master_uP function, it is commented out in the default camera code.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 21-01-2006, 17:15
Windward's Avatar
FRC #1452
Mine isn't commented out.
Unread 21-01-2006, 17:41
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
As pointed out above, the *call* to default_routine() from Process_Data_From_Master_uP() is probably still commented out. This is done for safety reasons. Also make sure that code in default_routine() doesn't modify the camera's pan and tilt PWM values.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 21-01-2006, 18:11
Windward's Avatar
FRC #1452
-Kevin
As I said, I checked in main.c and it is not commented out, unless it is called another time which I didn't check.
Unread 21-01-2006, 19:17
AKA: Alan Meekins
It, default_routine(), should be called from user_routines.c by the function Process_Data_From_Master_uP(). Another way to make modifications is to just edit Process_Data_From_Master_uP().
Unread 21-01-2006, 20:31
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Also make sure you aren't calling any other functions that modify PWM values after Default_Routines().
Unread 25-01-2006, 18:11
Windward's Avatar
FRC #1452
My bad. Turns out it was commented out somewhere else (or I went without sleep to long).
When I uncommented Default_Routine(), the camera started acting strange. The pwms would switch numbers back and forth such that the camera was vibrating.
I checked the code to see if it changed the pwms for the camera, and didn't find anything.
Unread 25-01-2006, 18:33
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Trouble is, in that Default_routine function you uncommented, there are other things that control pwm01 and pwm02. So you, at the top of default_routine, just delete those two lines of code that modify pwm01 and pwm02.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
