My team is not building a robot with the ability to shoot into the center goal. Instead, we will simply gather balls and dump them into the corner goals. During autonomous mode, we simply want the robot to drive up to the corner goal and dump all 10 starting balls into it.
The problem seems to be that there are no vision lights on the corner goals. There is no green light above the corner goals for sure, and unless I am very much mistaken there is also no infrared source (any infrared beacon) near the corner goals. So, can anyone think of any way of making an autonomous mode that will have the robot drive up to a corner goal? I have heard something somewhere about it being possible to use the infrared sensors to detect obstacles, and thus being able to detect a hole in a wall. Is this true? Is it possible? If so, how difficult would it be to implement? Also, it has been suggested to me that I could use the CMU cam to look for shapes. Then, I could look for the red or blue rectangle surrounding the corner goals. I am completely new to using sensors: in previous years, our robot had no autonomous mode. I believe that the CMU cam idea will not work because there are lots of red or blue rectangles on the field, for instance the starting positions. However, I would very much appreciate someone else's opinion on this and any ideas on how to implement the autonomous mode I described. |
Re: Scoring Corner Goals During Autonomous
How about at the start of a match you place your robot so it is aimed to drive right at the corner goal nearest to the start position. You could program it to follow the wall (mechanically by having a horizontal wheel run along it, and having your robot have a bit of drift into the wall or electrically by using sensors). Dead reckoning has been used a lot in the past, may work really well for getting the corner goals. Also, dead reckoning would be quicker and easier programming than the CMU cam.
Good luck! |
A good dead reckoning program with time could do what you want if you just wanted to drive strait to the goal in line with your robot's starting position or using wheel encoders and a gyro you could get your robot to where you want it to go.
Range sensors do exist. So, you could measure the distance from the wall and have the robot stop at the same distance each time. If you have a radio shack near by they sell VEX Ultrasonic Range Sensors which do this. There are also IR range finders as well. |
Wow thanks for the amazingly quick replies. It's nice to know that for once in your life you're in a forum that's actually helpful. I am a newbie to programming using sensors. Could someone explain to me what dead reckoning is and what would be involved in making such a program? And about the CMU cam - what exactly does it do? Does it return a matrix of pixels or what? Yes, I am planning to position the robot to drive straight to a corner goal in the beginning of the match. It has also been suggested to me that I might know that a corner goal is there by detecting the robot go up a ramp - the corner goal is up a light ramp. Could someone please give me an opinion on this idea?
Dead Reckoning is usually just telling your robot to do something for a specific time and not take any information from the out side world. It would involve setting up a timer or using the 26ms loop and have your robot do something for so many loops like drive for 2 sec and then turn for 1 sec something like that. It is not the most reliable way to do autonomous but it will work.
Let's handle these one at a time
The best way to develop stuff like this is incrementally. Do something like you propose above, and then come up with improvements and alternatives. It's nice to have a "library" of autonomous functions your bot can do, so you can select one before the match (including the most impressive "sit there and look pretty" autonomous mode, 'cause sometimes you'll be in a match where that's the best strategy, since you might be teamed with other bot's whose autonomous modes and capabilities might conflict with yours). And remember, it's often better to do one thing really well, than do a bunch of things poorly. Good luck, and ask lots of questions. The folks here are very helpful. |
#10
FIRST most definitely allows non-kit, Commercial Off-The-Shelf (COTS) sensors. You have a limit of $200 USD per electronic item max. |
#12
Since you say you are completely new to sensor systems, let's start off with the ultimate in simplicity and go from there. An extremely simple (and it turns out, very effective and incredibly inexpensive) solution works like this:
step 1: Attach two simple bump sensors to the front corners of your robot. These "bump sensors" can be simple microswitches that are normally open (i.e. when connected to the digital I/O ports on the RC, they provide a "0" indication), and close when they make contact with some object (and thereby change the state of the digital input to "1'"). step 2: Position the robot in the starting square closest to and facing the corner goal (i.e. as you stand at the center of the long edge of the field, facing the field, put your robot in the square to your right, and have it face the corner goal to your right). Then have the robot execute the following instructions: step 3: Turn to the right until the bump sensor on the right front corner of the robot hits the edge of the field. This aligns the robot drive direction with the edge of the field, heading toward the corner goal. step 4: Drive forward until BOTH sensors detect contact. This will indicate you have hit the player station wall. Stop driving. step 5: Spew out the balls into the corner goal as fast as you can. step 6: All done. Once you get this simple sensor implementation nailed down and working, then you can start to get a little fancier. Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do. The only difference is that instead of just telling you when you have actually made contact something by bumping into it, the ultrasonic sensors can tell you the approximate range to an object as you begin to get close to it. So you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" And yes, using the ultrasonic sensors from a VEX kit is permissible under the current rules. |
#13
Thanks for all the ideas, people. There's definitely enough here to get me started. Though about that idea with bumper sensors - it's a logical idea, but if I have bumpers on my robot and go at full power until I run into a wall, and I have bumpers, don't you think that the robot will bounce off the wall and back down the ramp? If it accelerates halfway across the field, the impact will be very strong, almost dangerous. Could someone give me an opinion on this thought please?
#14
since you know the approximate distance to the wall you can use sort of dead reckoning and tell the robot to slow to half or quarter speed at a certain time during its autonomous journey.
#15
Not to pop the simple bubble, but I have another idea. AFTER you get something simple working, I say try the camera, the light may not be over a corner goal, but its in the same spot all the time and your camera will be in a fixed spot on your robot. It's actually fairly simple to lock on to the camera and use it to figure out where you are based on the servo values, PM me if you'd like more help, I've already written a simple autonomous mode to go to field waypoints based on the light and camera, you could easily use it to drive up to the corner goal, know for sure you're there and dump, and a properly mounted camera deep inside the robot will probably be less likely to be damaged. And it's honestly not very much more complex, Kevin's camera code does a fantastic job of making it track, you just need to take the information from that and use it to drive, it can be very simple, a proportional control will probably do.
Code:
#define Kgain 1 // Adjust this, trial and error for best results, varies by robot #define TARGET 160 // This is the servo position you want the goal to be at, also trial and error signed int pan_error; pan_error = PAN_SERVO - TARGET; //This calculates a positive or negative error for the target, negative is too far left, positive is too far right pwm_XX = pan_error * Kgain; |
| How fast can the corner goals detect balls going in? | Excelsior | Technical Discussion | 3 | 01-22-2006 01:24 AM |
| Question: Can robot block lower goals to prevent scoring? Seems unfair. | 456RoboChick | Rules/Strategy | 1 | 01-11-2006 08:04 PM |
| A Warning to Human Players During Autonomous | The Lucas | General Forum | 21 | 04-07-2005 02:29 AM |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 06-24-2002 03:13 AM |
