Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 22-01-2006, 03:09
AMIRAM AMIRAM is offline
AMIRAM is an unknown quantity at this point
Gear Tooth Sensor
Hi
can anyone tell me how to connect the gear tooth sensor to the gear
we got this year ?
do i need to connect it insid the gear ?
this is my first year...
thanks
Unread 22-01-2006, 03:54
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Gear Tooth Sensor
Today, we were working with them. You have to mount them next (on the outside, not inside) to the gear or sprocket that you are trying to count. You need to have the bottom of the geartooth sensor a few mm away from the teeth, but make sure that it doesn't hit the gear or sprocket since it might damage it...and that'd be bad.
http://www2.usfirst.org/2006comp/Spe...oth_Sensor.pdf
Also, next time, search before you post:
http://www.chiefdelphi.com/forums/sh...ght=gear+tooth
Unread 22-01-2006, 04:09
do u mean outside near the chain ?
do u have a scematic or a picture ?
Thanks
Will the gear tooth break? sanddrag Technical Discussion 11 23-01-2006 14:24
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear tooth sensor vs. Optical Encoders Avarik Programming 7 17-01-2006 10:18
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
Gear tooth sensor issues Nine9cracker Electrical 2 17-01-2006 02:37
