Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Unread 22-01-2006, 13:29
BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
Camera Is Spazzing Out!
I've posted a few questions in various places and I've decided to bring it all together in one thread. We're having major issues with our camera and we can't figure out what's wrong.
At first, we couldn't get the camera to scan, but now we can. Also, we can't figure out what we changed in order to allow the camera to scan. Now, when we turn our robot on, "scanning..." appears for a little bit. After that, the camera will start saying that it sees the target, as if everything is green. The red light on the camera, which we noticed is on when the camera tracks, will blink randomly as the camera says it can see the target. If you put the lens cap on, the camera scans perfectly, so we know there's something wrong with what the camera is seeing. The camera is perfectly calibrated in LabVIEW, and we've done exactly what the manual says. We just don't understand what is making the camera do this.
We're all novice programmers, so we just don't know what to do. Any help at all would be absolutely amazing. Please help!
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
