Go to Post If time only weren't a factor, everything would be done. - Schnabel [more]
Unread 22-01-2006, 21:31
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
Dewalts modification suggestion
If you are shifting with Dewalt transmissions and if it seems your servo doesn't have enough torque while shifting you may consider removing the spring clip on the top of White Plastic Shifter Tube. This locks into indentations on the bottom of the Magnesium Housing, more specifically, underneath the numbers that indicate which gear you are in.
as per Dr. Joe's request here is a picture, items in red are the ones previously mentioned.
gl everyone
P.S. credit to RogerR for this solution
Unread 05-07-2007, 13:21
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Re: Dewalts modification suggestion
We had this problem in competition with one of our DeWalts, and instead of totally removing the clip, I just bent the clip in with some needle nose pliers so that it provided less resistance.
The clips are nice because the lock the DeWalt into a gear, so your servos don't have to be calibrated as precisely.
Team 418 Purple Haze
http://www.lasarobotics.org/
White Paper Discuss: Nothing But Dewalts Joe P Extra Discussion 112 22-01-2010 00:24
Dewalts Used Last year Xufer Motors 12 19-01-2006 21:57
Joystick Modification Question wmurphy Control System 2 31-01-2005 00:29
one suggestion to make this forum better Ken Leung CD Forum Support 34 23-01-2005 12:42
Another forum suggestion Kris Verdeyen CD Forum Support 2 11-06-2002 19:52
