Go to Post The FIRST community will always step up in times of need. - nikeairmancurry [more]
Unread 23-01-2006, 13:50
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Ball Compression?
For those of you who are using rollers to shoot your ball, how much compression are you using on the ball to get more traction? For example, the prototype I made this weekend had a roller and a plate, with a 6" gap between them, so that is a 1" compression on the ball.
Also, I have noticed that the faster you spin the wheel, the less compression you need. Hence, along with compression, what is the surface speed of the rollers you use?
Thanks.
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
30" ball sits up there real pretty archiver 2001 18 23-06-2002 22:49
