| Thread Tools |
Rating:
Display Modes |
#16
Re: Mounting / Connecting The Fisher Price Motor
This really is an easy (with access to a lathe), light way to do it. The entire aluminum slug with bolts weighs maybe a few ounces, and the necessary shaft support can be as light as you want to make it. |
#17
How about a proven method to take power off from the next-to-the last gear? IIRC, this stage is about 450 RPM.
#18
I'm still a bit confused how this would work? Would the slug have a shaft on it like the whole thing milled/lathed out of one aluminum rod? |
#19
On the white output of the fisher-price, there is an octagonal hole formed by tabs. It appears to be round at first glance. So, by maching a round slug that fits in this octagonal hole closely, you have now effectively "Plugged the hole". Between the slots of the FP output, you drive bolts through, into holes tapped on the Aluminum slug. So, the slug can then have whatever you want on it. Want to drive a 1/2" shaft with it? Machine and broach a 1/2" hole into the Al slug! All it is is really plugging the output hole with something that is easy to interface. |
#21
I was talking with one of our mentors about connecting to the FP gearbox output "shaft"
And the first thing that he said was that a 1in or 1 1/2 in nut would fit in there We haven't been able to get a nut that big yet, but I believe that this may also be able to solve our problem |
#22
Very interesting solution. But arn't most nuts hexagons, and not octagons?
| Cheap Torque Measurement? | ChuckDickerson | Motors | 15 | 13-06-2005 13:57 |
| Use of the fisher price motor ALONE | Some Guy | Motors | 6 | 03-02-2005 08:55 |
| Fisher Price Motor Into Drill Gearbox | Chris | Technical Discussion | 11 | 21-04-2004 09:09 |
| Locking the Fisher Price Motor | xxlshortys | Motors | 10 | 24-02-2004 21:24 |
| New Fisher Price Motor - IMPORTANT | Paul Copioli | Motors | 6 | 08-02-2002 13:35 |
