Go to Post Our team has one goal: be ourselves. - PayneTrain [more]
Unread 24-01-2006, 16:52
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
pic: Top Gun Team 1294 Teaser
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 24-01-2006, 16:53
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Talking Re: pic: Top Gun Team 1294 Teaser
A jail for naughty balls!
Unread 24-01-2006, 20:37
spamified88's Avatar
spamified88 spamified88 is offline
AKA: Sean
FRC #1257 (Parallel Universe)
spamified88 will become famous soon enoughspamified88 will become famous soon enough
Send a message via AIM to spamified88
Plinko played with POOF balls instead of chips?
Head rule guru, I know everything, or at least I'm supposed to...hehe
PARALLEL
UNIVERSE
Unread 24-01-2006, 21:14
I do think it looks like a big pachinko machine, without the garish paint job.
Unread 24-01-2006, 21:21
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
HMMM 3 drills and blocked in poof balls.HMMMM It's a POOF ball torture device.
Corry Robotics Team 306 1999-2015
Unread 24-01-2006, 22:08
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
That looks nearly identical to the design I am trying to convince my team is a good idea. They're stuck on a stupid hopper.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 24-01-2006, 22:47
Tell them they're wrong. It works like magic, even without bearings on the shafts, and with some mathematic relationships that need tweaking. I haven't timed it, but it can move a half-dozen balls up from the bottom to the top faster than a human can feed balls into it. Tomorrow we are adding the prototype shooter to the top and hooking up the prototype scooper to the bottom (sort of). Then, the fabrication team has to replicate it in more primitive materials like aluminum and lexan.
Unread 24-01-2006, 23:07
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
But plywood is so awesome on robots...... But I guess shiny usually always wins out huh?
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 24-01-2006, 23:21
robotaddict's Avatar
robotaddict robotaddict is offline
FRC #1294 (Screws Loose (hopefully going to be changed soon))
robotaddict is on a distinguished road
Some words from the designer
Well, what this thing is used for is feeding balls from the bottom of the hopper up to the shooting wheel. Sorta like this:
./..........<---adjustable angle firing thingy
|....O_....<---firing wheel
..\__....|
......O...|..<---feeder roller (made out of 3/4" hollow aluminum tube and pool noodles)
Ya, sorta like that. I had planned to have a continuous ramp thingy, but my dad decided to try it without the plywood over the dowels and it worked great. I had also originally intended just one feeder roller, but that didn't get enough height past the base of the hopper so my dad suggested another S bend with 2 more rollers, and it works well. It maintains about an inch of compression on the ball all the way up. The reason it feeds from the bottom is to allow the angle adjuster to rotate around the firing axle without being limited by a gravity feed-tube coming from above or the side. Anyway, I hope this helps your design or gives you a few good chuckles.
"Say, what rhymes with 'run for your lives'?" -Flavor text on one of my favorite MTG cards
"THAT SHOULDN'T BE PHYSICALLY POSSIBLE!!!" -Response to the combo I based on that card
"You might as well put a sign on it that says 'I'm a gigantic nerd'." -My dad
John, head programmer of team 1294 and gigantic nerd.
Unread 25-01-2006, 07:59
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
How many balls can fit in there at one time?
And.. what is driving the balls? Is that foam noodle material I see? (the yellow)
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 25-01-2006, 11:39
Robotaddict is my son. He designed it and I helped him build it.
The loader holds seven balls internally. He wants to use a sensor (TBD) to pulse the single feeder motor just enough to load one ball to the shooter each time the firing button (TBD) is pressed. Behind the loader will be a narrow (one ball thick) hopper which will hold another 8-10 balls fed by a one-ball-thick scooper across the back of the bot. We are big on one-ball-thick designs since we know that any other configuration would lead easily to ball jams of squishy poof balls.
Making rollers out of thin-walled 3/4-inch aluminum inserted into pool noodles was my contribution to the design. They are ultralight, cheap, and strong enough. The 1/4-inch steel axle pins in the ends are heavier than the whole rest of the roller. We might wrap the noodles with a rubber surface (something like a bicycle innertube slit open and wrapped around it) to improve grip.
Cheap and effective -- two words that should be the FIRST slogan.
Unread 26-01-2006, 19:38
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Thanks for the prototyping idea with the drills. That should save my team a day or two in making up its mind about ball mechanisms. I'm pushing a similar design with conveyor belts between the rollers.
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 25 teaser CD47-Bot Robot Showcase 2 21-02-2004 17:58
