Sprocket
Can we tap and die the sproket on the out drive shaft so as to hold the sproket in place?
Re: Sprocket
A lot depends on your set up, however, I would try to find another method (welding, cutting a key, pinning...). One of the most probable problems would be the sprocket "unscrewing" itself from the shaft depending on the direction of rotation.
Re: Sprocket
It seems as if you may have intended for this question to go in the official FIRST Question & Answers forum.
That can be found here: http://forums.usfirst.org/forumdisplay.php?f=52 Please be aware that any answers you find here are unofficial and may be incorrect or inconsistent with how FIRST interprets your question and the rules. |
Re: Sprocket
Sounds iffy to me, why not try set screws?
Re: Sprocket
To Quote Woodie Flowers "Setscrews inhale audibly."
Re: Sprocket
Can you legally? Yes. Should you? Maybe not. Using threads is not the best way to transmit torque. At the least, you would also need a left-handed threaded hole int he end of the shaft in which you place a retaining bolt and washer, like how a drill chuck is held on.
| Vex Robotics Sprocket and Chain Kit | Morenoh149 | FIRST Tech Challenge | 3 | 08-01-2006 22:39 |
| Stuck sprocket - need advice | sanddrag | Technical Discussion | 20 | 13-10-2005 12:12 |
| Need to find 5/8" sprocket | hedgehogger | Kit & Additional Hardware | 3 | 14-02-2004 09:23 |
| chain ridding up and off sprocket problem... | davidhoare | Technical Discussion | 4 | 04-02-2004 10:13 |
| If set screws suck . . . | Madison | Technical Discussion | 17 | 22-12-2003 19:19 |
