Go to Post Part of being an effective leader is knowing your own personal limits. - artdutra04 [more]
Unread 24-01-2006, 23:22
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Speed Sensor for Ball Shooter
Does anyone have and idea for a speed sensor for the ball shooting wheels, I don't really want to use encoders, I had an idea of using a frequency to voltage IC and connecting it to the analog port of the R/c as I don't need direction or exact positioning and would rather not go into interrupts. The wheel would have an optical sensor mounted with a disk on the shaft or something similar, however all the frequency to voltage chips I saw wanted about 15 volts in and like 100Hz. The frequency is doable, but theres no way I want 12v battery voltage going into the r/c if something goes wrong. So anyone have an idea?
my priorities
Very little coding
cheap
commonly available
easy to interface
not necessarily in that order.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
