our team can't find the stud terminal block, or maybe some call it a ground stud, its the screw with a nut, in a black stand type thing, it a small part used in the electronics.
do you know a place like an internet site where we can buy it. we need this part so all help would be greatly appreciated. thank you. |
Re: help needed with stud terminal block for electical
I don't know where you would buy these from. A quick Google around didn't turn up anything. I think your best bet would be to e-mail FIRST.
FRC e-mail: frcteams@usfirst.org Good luck, JBotAlan |
This one looks quite similar but you should verify http://www.delcity.net/delcity/servl...d=71704&page=1
sorry but we really need this part, ant first takes for ever to reply, so i thought posting it on different forums would get us results faster. i'm very sorry
Re: Help needed with finding stud terminal block from KOP
In the past this is where we ordered the part.
Terminal Supply Co. (800-989-9632, Carrie) www.terminalsupplyco.com Stud - Insulated - 3/8inch diameter Part NumbeR: tb-1 |
Last year's breaker panel has a ground stud right on the panel that you could use.
thanks for your post though |
#10
need help finding stud terminal block (PLEASE HELP!!)
#11
Re: need help finding stud terminal block (PLEASE HELP!!)
Please! This is the third thread I've seen regarding this from you! I would help if I could, but I can't! Stop before your reputation points get bombed!
E-mail FIRST. They will get you pointed in the right direction. frcteams@usfirst.org JBotAlan |
#12
Please do not double post. There are people who will help you out when they become available. Other then that, look to see if the part number or vender is in the 2004 manual, as they were supplied in FRC 2004.
| Stinger Fuse Block and Power Distribution Block | Don Wright | Electrical | 2 | 03-30-2004 10:45 AM |
| Do we need to use the gnd stud and MAXI fuse block | Noah Melamed | Electrical | 14 | 03-03-2004 08:38 PM |
| Power Terminal Block Model | Ed Sparks | Inventor | 1 | 02-11-2004 06:55 AM |
