Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 25-01-2006, 19:39
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Question Issues with MPLAB 7.30
At http://www.ifirobotics.com/rc.shtml (all the way at the bottom) it said not to use a MPLAB Version greater than 7.20:
NOTE: To Compile 2004, 2005 or 2006 code, use MPLAB ver 7.20 and C18 Compiler ver 2.40 (newer versions can not be used)
Does anyone know why?
I ask because MPLAB 7.30 supports Subversion (for version control), while 7.20 does not.
Thanks in advance,
Robinson
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
