Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Unread 26-01-2006, 02:13
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
Team Role: Leadership
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
T-Slot extruded aluminum
I have read a lot about t-slot extruded aluminum and their advantages (versatility, range of options, prototype ability) and drawbacks (weight, cost) but i haven't found any figures on just how expensive this stuff is per foot.
I am looking at either 1"x1" 80-20 or 30mm x 30mm bosch or item.
I understand fasteners are even more but i just want to know a ball park figure.
This is for the upper level of the robot and will be used to build the hopper and flywheel mounts and will extend up from the kitbot chassis.
Using Extruded Aluminum to telescope. LGuY Technical Discussion 21 07-02-2005 12:43
Torsional Stiffness of Extruded Aluminum Ben Piecuch Technical Discussion 3 19-01-2005 21:55
where can I get info on extruded aluminum? SCYTE16 General Forum 21 13-01-2005 14:23
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
