Go to Post And then I learned how to use the lathe...long story short, I ditched my plans to become a music major and became an engineering student. - Karibou [more]
Unread 26-01-2006, 06:17
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
Gyro not accurate - Problem
Hi,
without calibrating the gyro too much, just by letting it calculate bias and then moving it (connected to a solid block of wood) 180 degrees and back, we saw that the gyro does not return to zero and actualey is off by 200-500 "numbers" each time (have not calibrated to radians or degrees yet).
so after one turn and back, instead of being at zero or very close it is around 500 and then after doing it again it will be at 700 or 300....
anything I can do to make it more accurate??
-Naor
atan Problem - Need Help the_undefined Programming 0 18-02-2005 11:16
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
