Go to Post Robotics competitions take place in the same "perfect" environment that basic physics equations take place in. :rolleyes: - Branden Ghena [more]
Unread 16-01-2008, 14:12
Jungle_Ed Jungle_Ed is offline
FRC #0405
Jungle_Ed is an unknown quantity at this point
Re: SONAR Sensor Software Driver
Hey I just got assigned to a 2008 FRC team. I am going to try using Mike 0.3 code then Qbranch's Code. Anyone, please let me know of you get some ok readings for the Sonar on and FRC robot, and I will be sure to do the same.
Unread 16-01-2008, 14:32
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
We got the Vex sonar working last night using Mike's driver. I'm really impressed by the whole thing -- it can see a 3' x 4' board at about 15 feet!
Note: the documentation that came with the Sonar sensor I got (from Radio Shack, back when they sold Vex stuff) had the "input" and "output" functions backwards. See my earlier post in this thread.
The wire marked "input" is an input to the sonar, and it needs to come from a rc_digital_io_NN pin configured as an output. You need to set a couple of macros in sonar.h to tell it which pin you are using for the sonar input.
The output needs to go to a digital_io pin that acts as an interrupt. We used rc_digital_io_01. I think that is the default in Mike's code.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 16-01-2008, 14:46
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Beware of off-axis error! Depending on what sensor you're using (Parallax PING))) is pretty much your best bet) the further a wall is off axis the worse your measurements will be.
For example, if you were, say, following along a wall and servoing off of the distance from the wall (no idea why you'd want to do that ) you're robot will swerve further and further until it crashes, because, each time the robot veers left or right it alters the distance the ping sensor percieves, even though the distance has barely changed. This escalates until, like I said, you crash.
Instead (and we've used this in the past) use encoders to drive your robot straigh, and use ultrasonics for obstacle detection/avoidance.
Getting a reliable distance to anything at any angle is our current goal at 1024.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 31-01-2008, 09:27
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
I have a quick question Mike Dubreuil. YOu ping the sonar with Ping_Sonar and turn the timer on. Then once it interrupts it goed into Hardware_Interrupt_Sonar an into the switch statement for SONAR_WAIT status and you turn the timer on again. Then it goes into the switch statement for SONAR_TIMING for the next interrupt and get phase width as a measurement. Is the phase_width the time it takes for the actuall sound wave to go through the sonar, not the echo from the wall? If it is the echo value, then why start the timer in SONAR_WAIT?
Thanks Stephen
Unread 02-02-2008, 13:29
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
I have the code setup as gnornhurst posted in the "SONAR Sensor Software Driver" and i'm using rc_dig_out16 for input and digital IO port 1 for "output", but I'm getting a "Cannot find Sonar" error.
I was wondering if there were any additional code changes you needed to make to get this to work with this year's Kevin Watson code?
Thanks.
Toshiba Cardbus Problem? jpsaul7usa Chit-Chat 12 01-01-2006 02:37
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Middle School Drivers ram General Forum 40 26-02-2003 17:01
