Go to Post What makes a team great is not what they do during the 6 weeks, but what they do the rest of the year. - davidthefat [more]
Unread 27-01-2006, 11:07
koenig3456 koenig3456 is offline
Programming Coach
None #0681 (EARTH Squad)
Team Role: Coach
koenig3456 is an unknown quantity at this point
Question Calling C functions from EasyC
I've written some functions in C using MPLab. The modules include both static data and code. How can I use them in an EasyC project?
Unread 27-01-2006, 11:23
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Calling C functions from EasyC
I think the answer is wait for next version of EasyC. See thread EasyC Wish List, esp. reply #4.
Regards,
DCBrown
Unread 27-01-2006, 13:27
Programming Coach
Team Role: Coach
Smile Re: Calling C functions from EasyC
Thanks for the hint.
I may have figured out a solution. I don't have access to the RC right now, so I can't test it. It does compile and link successfully.
This is what I did:
1. Compile the C code using MPLab.
2. Use mplib.exe to add the .o file to the wpilib.lib in the EasyC folder.
3. Add the header file to EasyC (Options/File Inclusion).
Unread 27-01-2006, 15:09
AKA: Bud
Clever. I hadn't thought about adding additional .o files to the default library. To use to environments where libraries are protected except for read access.
We have a need for something similar, can't wait to try it.
Regards,
DCBrown
Unread 27-01-2006, 16:03
AKA: Bud
Tried something similar just now...
1. Use MPLab to create .o object files
2. Use command window, use mplib to create .lib file (mplib /c MyTest.lib)
3. Add .o files to my library (mplib /r MyTest.lib MyTest.o)
3. move a copy of my library MyTest.lib to c:\mcc18\lib so it can be found by EasyC during link time
4. update <processor>.lkr file under EasyC in Frc\18F***\ to reference my library, e.g.
FILES clib.lib
FILES p18f8520.lib
FILES MyTest.lib << added this
5. Referenced functions/data in MyTest.lib in EasyC... compiled/linked correctly.
Regards,
DCBrown
EasyC Wish List dcbrown Programming 32 14-08-2006 09:24
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
