Go to Post It is very difficult for a large, inexperienced, impatient group to create order from chaos. - Wayne TenBrink [more]
Unread 27-01-2006, 19:35
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
[Help] OI Modification
What is the legality of opening up the OI and, say, replacing some of the LED's with piezoelectric speakers? I'm thinking a lock-on tone (when the camera has a lock on the target at 5ft., and has aligned the launching mechanism accordingly) would be a lot better than a lock-on LED. Taking your eyes off the robot to keep checking for a lock = bad.
Unread 27-01-2006, 19:53
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: [Help] OI Modification
Not even remotely legal. Remember though that the OI has LED outputs available on some of the joystick ports - but you can only draw 10ma of current from them.
Another consideration is that the competition venues are extremely noisy and it might be very difficult to hear a buzzer or sound.
Unread 27-01-2006, 20:03
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
definatly illeagal, but also if you screw up and break your OI you void your warrenty...
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The definitely legal way to do this: attach a portable computing device (see <R74>, <R77>, and <R78> for applicable rules) and rig it to give the sound. This is assuming you can hear the noise in an arena with loud music and cheering, of course. I'm not sure that modifying the OI in this way is legal, even if it were a good idea (which it isn't).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 27-01-2006, 20:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
See the OI documentation available here. The LEDs are "echoed" on the PWM connectors. If you can find a beeper that works at 10 milliamps, and that you can hear over the noise at competition, go for it.
If the issue is just not wanting to look away from the field to see the indicator, you might consider a "head-up display", with one or two LEDs mounted to the corner of your operator's safety glasses and wired to a connector on your OI.
Unread 27-01-2006, 20:25
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
See the second sentence in Rule <R61>.
It has been said before, but it is worth saying again: please read ALL the rules for the game! In particular, read sections 3,4,5 and 6 carefully. The manual is chock-full of really useful information.
The 2006 FRC Manual: Read it. Learn it. Know it.
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 27-01-2006, 22:07
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
If you're looking to do a lock-on indicator, a visual cue is much more effective field-side. Back, in 2003, 67 used a hat-mounted LED to tell the stacker operator when the stack was secured by the stack-hold-down mechanism. So, in any case it is possible, and in fact, we're probably going to do the same target-lock idea you're aiming to do this year as well.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 27-01-2006, 22:33
FRC #1940
Ooh, I like that idea a LOT more, actually. We'd need a hella bright LED array, though. Anyone know where to get a bunch cheap blue LED's (don't say Radioshack, because I said *cheap* LED's)?
Speaking of LED's... is it legal to interfere with other teams' guidance systems (i.e. spewing lots of IR all over the field in order to mess with proximity sensors). I know it's not legal to cause physical damage, but the rulebook said nothing on this sort of defense.
Unread 27-01-2006, 22:36
FRC #1940
How many portable computing devices are we allowed to bring? (I was thinking along the lines of a laptop for software reprogramming/modification, and my PDA to link to one of the serial ports to display performance data, etc.).
Unread 27-01-2006, 23:38
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
Team Role: Coach
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
You may bring as many computers as you want to the competition, for use in the pits. However, that doesn't mean you will be allowed to use them on the field.
Oh, maybe I shouldn't have pushed that...
Unread 27-01-2006, 23:48
Software Engineer
Rookie Year: 1995
The LED outputs on the OI are current-limited to 10 milliamps. This basically means you can connect only one LED to each output.
You really should read through the whole manual... this question is also addressed directly:
<R31> No devices or decorations are permitted on the robot that are intended to jam or interfere with the operation of the vision system (i.e. changing robot color to confuse opponent’s vision system).
<R59> Custom Circuits may not:
• Interfere with the operation of other robots
Unread 28-01-2006, 08:24
FRC #1940
Is that in the Game section or Robot section (dont have a rulebook handy on me at the moment).
@Edit
Also, the "hella bright LED array" would not be on the OI, but rather on the robot itself (as had been suggested for a visual-cue for a lock-on, as opposed to a (however cool) lock-on tone).
Is there a milliamp limit on LED`s on the robot itself?
Unread 28-01-2006, 09:02
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You won't find any rules for this but Gracious Professionalism keeps you from even thinking about it.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 28-01-2006, 09:13
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
It's also illegal to use this "defensive" method.
FLOWCHART: (Page 14, Section 5) Question 1: "Is the part a safety hazard or likely to damage robots, the field, or interfere with the humans or the controls?" ---> "YES" ---> "No! It may not be used!"
Also ...
It was mentioned above that you can bring as many laptops and PDAs as you'd like, but as for using them on the field, that's a no-no.
• Directly alter the power pathways between the battery, fuse blocks, speed controller/relay, and motor. Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the robot’s electrical system is acceptable, because the effect on the robot outputs should be
inconsequential.
• Directly affect any output devices on the robot, such as by providing power directly to a motor, supplying a PWM signal to a speed controller or supplying a control signal to a relay module
Be used for wireless communication, such as sending or receiving a signal to and/or from the alliance station
Connect to the radio or tether ports on the Robot Controller
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
  #15   Spotlight this post!
Unread 29-01-2006, 00:46
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
inconsequential.
Yes--and no. You are allowed to hook them up to the OI, as per the rules in my previous post in this thread. You can have the RC tell the OI to make x device make y noise. That's legal. Having a portable computing device (laptop, PDA, etc) on the robot--the inspectors will call you on it pretty quickly, and so will the refs if the inspectors miss it.
Past teams:
Dewalts modification suggestion Stephen Kowski Motors 1 05-07-2007 13:21
Globe motor modification Veselin Kolev Motors 11 26-01-2006 15:35
Joystick Modification Question wmurphy Control System 2 31-01-2005 00:29
Modification on the Torque motor? archiver 2001 0 23-06-2002 23:45
Caster Modification archiver 2001 1 23-06-2002 22:58
