Go to Post Thinking (or the lack of it) will be our downfall. - sirbleedsalot [more]
Unread 27-01-2006, 20:06
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Question Problems Using PID for Velocity
We have a PID control loop to control velocity of a motor. We have the tooth counter giving us our current velocity, and an OI analog input giving us our target. The code is written such that the motor can never go backwards. (The tooth counters are giving us a speed of about 0-18, we're hoping to increase that range a little.)
The problem is that, when using only a P loop, it oscillates violently at mid- to low-speeds. Meaning that it revs up, then stops, revs up then stops, etc. (Victor set to coast.)
Anyone seen this before in their own code? Any recomendations on using PID for velocity->velocity control loops?
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Anyone Else Having Problems with Q&A on FIRST? Windwarrior General Forum 6 25-01-2006 10:54
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
All-Time PID Drive with Hall-effects: Coming along very nicely jdong Programming 6 05-02-2005 19:39
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
