Go to Post I guess you really do learn something new everytime you go to a FIRST competition. - Elgin Clock [more]
Unread 30-01-2006, 22:33
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Re: Newbie Needs Help
The IFI loader we have is v1.1.0 and we downloaded the camera codes from Kevin's website yesterday.
Unread 31-01-2006, 16:43
sT4s1657 sT4s1657 is offline
FRC #1657
sT4s1657 is an unknown quantity at this point
I have the same problem with kevin's program (frc_camera_s and frc_camera)
so i tried the FRCcode2.4(something like that) and it work fine for a while but now when i tried to get this to work with the gyro and the accelometer the RC got stock, and now i cant get the camera working again....
Unread 04-02-2006, 10:55
None #0333
I still need help. The camera is still not responding to the code. HELP!!!
Thanks in advance.
Unread 30-01-2006, 20:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by itzrobz
We hooked up the TTL adapter and a PWM cable between the camera and the RC, the servos into the PWM outputs, and the camera power into one of the PWM outputs. The thing we don't get is that where the serial cable is supposed to be hooked up to. We hooked it up connecting the COM port of our laptop and the Programming Port on the RC.
Don't hook up both the DB9 cable to the computer and the "PWM" communication cable to the RC at the same time. They'll interfere with each other. Only use the computer if you're controlling the camera with the computer, and only use the cable to the RC if you're controlling the camera with the RC.
Unread 30-01-2006, 20:46
None #0333
Ohhhh, I understand now. Another stupid question:
I can hook up the RC to the computer and use the "PWM" communication cable to connect to the camera (from the RC) at the same time right?
Thanks
i am a newbie at the camera Capozzi Programming 3 28-01-2006 10:56
AHHH! I'm a lost newbie! I need help! lkdjm Programming 8 28-01-2006 08:41
quick question as a newbie Kristian Calhoun General Forum 8 26-10-2005 15:15
spur gears & fishers ...newbie question... archiver 2001 3 23-06-2002 23:17
Total newbie to the Chairman's Award A. Leese Chairman's Award 4 06-06-2001 22:03
