Go to Post Great CAD ** work! ** Cardboard Aided Design - philso [more]
Unread 28-01-2006, 11:38
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
Camera Servo Problems
We have a problem with the servos being connected to the CMU board. We are using EasyC for programming (a lot easier for our team, for various reasons even though I know "hard" C). We are currently using the Servo block to set the servo position using joysticks (for testing purposes). We are basically set up like this:
pan = p1_x
tilt = p1_y
Here's the problem, whenever we move it over to around 110, the servo jumps to 46 (i'm guessing seeing it's the servo limit) until around 100 when it jumps back to where it should be. The same thing happens on the other side at around 144 it jumps to 46 until 154 when it jumps back.
Here's what I've tried:
-I've tried all five camera servo ports, they all do the same thing
-I've tried different servos, no change
-I've hooked the servos directly into the RC adn they work just fine
Here's what I plan to try:
-Hooking up the camera to LabVIEW and seeing if the same thing happens under it's control
-Swapping out the camera board with last years to see if it is a bad board
Any one have any similar experiences? Any other ideas?
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Strain With Camera DanDon Motors 6 13-02-2005 08:49
Camera Problems pickle Programming 21 20-01-2005 20:43
Camera "Grab Frame" Problems Isabel Cole Programming 7 15-01-2005 21:53
