Camera Jitters
With the streamlined version of Kevin's code loaded into the FRC Controller, the camera will sweep as it looks for the target. When the camera.c/h terminal.c/h and tracking.c/h is added to our code and
Tracking_Info_Terminal(); Camera_Handler(); Servo_Track(); is called in the Process_Data_From_Master_uP in user_routines.c. With the code loaded into the FRC Controller, the camera will only jitter in place. Any help would be appreciated. |
| CMU Camera kills robot controller if not found. | Chris_Elston | Programming | 21 | 27-03-2006 14:30 |
| How To Use the Google Camera | generalbrando | Kit & Additional Hardware | 2 | 07-02-2006 16:00 |
| Camera Is Spazzing Out! | BrittanyV | Programming | 15 | 04-02-2006 13:39 |
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 11-01-2006 17:42 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
