Go to Post Focus on solving the problem, not on being deliberately creative. If you effectively solve the problem, creativity is naturally leveraged as part of finding a great solution. - Jim Zondag [more]
Unread 28-01-2006, 22:50
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Timer0 Interrupt Behaviour
I'm trying to write some code (actually, modifying Kevin's) with a defunct MPlab, so unfortunately I can't check myself with a test build this weekend. I'm using timer0 as a timer, and have it configured for 10mHz (Or 100 ns). I intend to simply, every 100ns, poll some variables. I have three questions:
1. The interrupt routine is called after the timer overflows. Does it overflow at it's frequency (10mHz)?
2. Do I have to turn off the timer, before I do anything in the interrupt? And will, when executed, the code just enter back into the timer, or do I have to somehow reset it?
3. Did I screw anything else up?
Thanks, interrupts are scary.
Code:
void Timer_0_Int_Handler(void)
 // this function will be called when a timer 0 interrupt occurs
unsigned char tenth_micro_seconds;
unsigned int micro_seconds;
tenth_micro_seconds++;
 if (tenth_micro_seconds>=10)
  micro_seconds++;
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Combining ADC, Serial, and Camera_s codes kaszeta Programming 6 22-01-2006 20:23
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Accelerometer code ImmortalAres Programming 28 04-06-2005 01:02
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Interrupts Questions mightywombat Programming 0 03-01-2004 14:50
