Go to Post No matter what route you choose, it's always a good idea to keep Mike Walker's cell phone on speed dial. - Joe Ross [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 29-01-2006, 11:47
animatorkid's Avatar
animatorkid animatorkid is offline
ouch
FRC #0079 (Team 79)
Team Role: Animator
Rookie Year: 2000
animatorkid is an unknown quantity at this point
Video editing help!
Ny team is having a problem. We found a video editor called avid freedv, and it is great. The problem is, it will not export the video with a dv-ntsc compressor, which is required by first for the 2006 animation. Does anyone know of a free video editor that will export a .mov file using the dv-ntsc compressor?
We have a very small budget for the animation (we're broke!).
Technically, if you placed a black hole on your robot with enough mass so that your robot is entirely within the event horizon, size constraints will no longer be a problem!
Is that smoke coming from from the victors or servos?!!!
:if only we had an electric beaver!"
you know you play online games too much when your teachers ask why you type "T" before every sentence.
Unread 29-01-2006, 12:06
Billfred's Avatar
Billfred Billfred is offline
Re: Video editing help!
iMovie HD (that comes standard on any Mac in recent history) comes with DV/DVCPRO - NTSC as an export option. You'll want to double-check to be sure, but that should work. You'd just need to find a Mac in your immediate vicinity.
Unread 29-01-2006, 13:16
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Adobe Premier Pro should be capable of that. you can download a mostly complete 30 day trial version from Adobe
Unread 03-02-2006, 22:00
jfelser jfelser is offline
FRC #0948
Team Role: Leadership
jfelser will become famous soon enough
Send a message via AIM to jfelser
My team does not have access to a Mac, and although Vegas works to export, the resulting video looks not good at all - much poorer quality than an AVI with DV-NTSC compression of the same size. Any tricks to get .MOV files with better quality while using the DV-NTSC codec?
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Unread 04-02-2006, 19:45
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
There is a trick my team found out. You can use the video post in 3ds max as a primitive form of a video editing. Since the required format is in the program already all you have to do is put the uncompressed avi files back into it.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 04-02-2006, 22:46
FRC #0948
Even using the 3dsmax export of the video, it is full of artifacts, and does not look acceptable to submit. I'm going to have my friend try to export using Premiere, which we've used in the past, and we'll see whether that gives better results. I admit I am kind of stumped here. Is anyone else having similar problems?
-Jake Felser-
Unread 05-02-2006, 12:12
ouch
FRC #0079 (Team 79)
Team Role: Animator
Rookie Year: 2000
Is the DV-NTSC compression format the same as the DV/DVCPRO-NTSC format?
Unread 05-02-2006, 18:07
abroerman's Avatar
abroerman abroerman is offline
AKA: Alex Broerman
FRC #0868 (Techhounds)
Team Role: Animator
abroerman is on a distinguished road
I'm having the same problem. I'm using Adobe AfterEffects 6.5 and exporting to "DV/DVCPRO - NTSC". The image quality is absolutely terrible - it's impossible to read text and make out details.
Does anyone remember what format we had to render to last year? If we can't find an acceptable solution I'm considering uploading 2 - one crappy one that meets their expectations, and a second using a different (though just as common) codec that looks decent. I'll experiment a little more with the export function to see if I can get it looking OK and let you guys know the results.
Good luck
Unread 05-02-2006, 22:05
BruceJ BruceJ is offline
FRC #0111 (WildStang)
Rookie Year: 2000
BruceJ will become famous soon enough
Good luck
I'm seeing the same terrible look exporting from Premiere 6.0 using DV/DVCPRO - NTSC at 100% quality.
If anyone hears of other options we are allowed to use to improve the quality and keep the file size under 250MB, please post here.
Thanks.
Unread 07-02-2006, 09:33
Team905Animator's Avatar
Team905Animator Team905Animator is offline
Mission Control
AKA: Casey Williams
FRC #0905 (Platt Tech Panthers)
Team905Animator is on a distinguished road
Send a message via MSN to Team905Animator
Id have to agree that the new codec requirement is bad. Any idea why they arent letting us use Cinepak this year? At least I was able to read my text efficiently with that.
Unread 07-02-2006, 19:19
FRC #0948
Ok, I think I have found the bottom of this codec issue. Seems that Apple came out with a new, improved, DV-NTSC codec with Quicktime 7. Also, if you have QT7, but installed certain other codecs afterwards, it changes the Apple DV codec to a different one, which does not play very well in Quicktime. To fix this issue, install (or reinstall) Quicktime 7 from the link below, and then rerender your animation on the highest settings (4:3 Progressive Scan worked best for me). My animation looks sharper than I've seen it before, even the raw uncompressed version, and is only 135 megs.
Helpful links:
http://www.m2w.net/reviews/dvcompression9808.html - Read about DV-NTSC.
http://www.apple.com/quicktime/download/win.html - Quicktime 7 DL Link.
-Jake Felser-
Unread 07-02-2006, 21:33
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Yes dvc pro describes the track width on the tape not the data and compression format. (dvcpro50 is another story)
Unread 08-02-2006, 16:57
ouch
FRC #0079 (Team 79)
Team Role: Animator
Rookie Year: 2000
Huh?
Could you put that in plain english?
I'm new to compression formats.
Unread 08-02-2006, 21:48
Tom Higgins Tom Higgins is offline
FRC #0180
Tom Higgins is an unknown quantity at this point
I'm having the same problem and have lost many hours trying all kinds of combinations of settings in exporting the final post production. I've used Adobe Premier for the last two years but exported in quicktime default which is Motion JPEG A compression also in 640 x 480 format. I've exproted in nearly all other codecs and they all seem fine except for the DV/DVCPRO NTSC required by AutoDesk. It's also a large file, ours is 200 MB whereas the "movie" compression gives a great, crisp, and smooth animation. Does anyone know who we might contact at FIRST or AutoDesk to get help on this problem? I've used the Max video post and its difficult to work with and really don't want to start editing again...We're done except for the final render.
Thanks
  #15   Spotlight this post!
Unread 09-02-2006, 00:32
Rookie Year: 2000
Thanks
I have installed QuickTime 7 as suggested, however I still get the same problem using Adobe Premiere 6.0.
Using 3ds Max 8, there is no problem using the DV-NTSC compression.
The alternative I'm going to use is to bring all of the audio and video into Premiere to line everything up, then ouput as a single movie using some method that still looks good (maybe some other compression).
Video post in 3ds max is simple enough just to create an Image input event set to the length of the entire animation and an Image output event set to the DV-NTSC compression for the final Quicktime movie that will be submitted.
Hopefully my plan works.
Video Editing Software? Kevin Thorp 3D Animation and Competition 16 07-11-2006 13:27
1604 Harmony Hurricanes promo video Barry Bonzack Robot Showcase 11 04-03-2006 18:56
Video: Cyber Blue 234 Late Night Programming Video JAH Robot Showcase 6 13-03-2005 00:34
Video Editing Software? Damelvin 3D Animation and Competition 8 21-02-2005 18:47
Good video footage miketwalker General Forum 0 28-03-2002 17:14
