Can't get EDU RC to print things.
I'm using the edu_serial_ports code, and none of my printf's will actually display anything.
Using the default code for it, which mirrors what you type into the terminal window, I do see output.. but that use's Write_Serial_Port_One(), not printf. Any suggestions? I've tried changing it to the second serial port, but that is apparently the TTL port. |
Re: Can't get EDU RC to print things.
-Kevin |
-Kevin |
| Are things quieter than usual this year? | Madison | General Forum | 23 | 26-01-2005 13:59 |
| [FVG]: Some things nobody seems to know about | Astronouth7303 | FIRST-related Organizations | 2 | 01-01-2005 21:03 |
| Simple things you can do to make your bot/team perform better | KenWittlief | General Forum | 21 | 01-04-2004 15:11 |
| A hint of things to come... | archiver | 2001 | 0 | 24-06-2002 01:12 |
