Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
Unread 29-01-2006, 20:10
Stephen P's Avatar
Stephen P Stephen P is offline
Team Role: Mechanical
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
pic: Team 1093 wheels
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 29-01-2006, 20:11
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: pic: Team 1093 wheels
That is a good solutions instead of buying wheels like IFI. The thing is you need to make sure you cover your screw heads with something so they don't touch the floor, epoxy works well. Nice idea
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 29-01-2006, 20:21
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Team Role: Teacher
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Now that is innovative...I'm suprised I haven't seen more of these in the past...
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 29-01-2006, 20:52
Stephen P's Avatar
Thanks. We turned down the wheels first to get them flat by spinning the motors and running them down with a sander, then glued and screwed the tread on. And the screwheads are sunk below the level of the tread, so it's legal.
Unread 30-01-2006, 00:11
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
Those almost look identical to ours, except we used 1 wheel and we used pop rivits to hold the thread on
Unread 30-01-2006, 00:16
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Did you glue the screws into the wheels? If so that is a bad idea because its going to be a pain to take them out to replace the tread (yeah the tread wears and you should change it before each regional you go to). Unless you have extra wheels you have done this to, you may wanna figure out how to take the glued in screws out.
Or if you glued the treads on it will also be a pain to take them off to change them. either way just screws or better yet if you can use them are pop rivets. Good luck.
Sorry if i read it wrong.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 30-01-2006, 01:00
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
It's a good design, 33 has used wheels like that a few times, and 1504 did last year and will again this year.
-Paul
Unread 30-01-2006, 01:12
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
That is clever. I like it a lot. Definitely something to keep in the playbook of possibilties. How much does each wheel set weigh?
Team Website
Unread 30-01-2006, 08:05
Stephen P's Avatar
Each wheel set ways about as much as 2 wheels and hubs combined (of course), i dont know how much that is but we certainly aren't trying to cut weight. The best thing about these are the cost, only about 3$ per wheel for the tread/glue/screws. IFI wheels are what, 80$ or more? And they can be easily pealed off the glue, it just ensures that they dont shift around side to side on the wheels. Only slight modification is needed on the individual wheel hubs to allow them to fit, and you need to get longer hub screws.
Pre-Rookie Teams - The How To Keith Chester General Forum 6 17-09-2008 00:28
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
