Go to Post We're not all autonomous robots who are preprogrammed to always follow rules blindly regardless of what they are. - Ryan Dognaux [more]
Unread 18-02-2006, 21:21
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Questions about first time trying 6WD.
Originally Posted by NHPilot
Question: If the center wheels are lower such that only four wheels touch at any given time, what would be the advantage of six wheels? I suppose it could be more manueverable for the short time it is teetering on the center wheels when weight transfers from front to rear for instance.
The fact that only 4 wheels are touching is what makes 6wd so advantageous. A typical 4wd setup has 4 wheels at the farthest corners of the robot, and therefore requires the largest amount of force/torque to turn the robot. If you were to shorten the front-back wheelbase with only these 4 wheels, the robot is now easier to turn. However, it can become very unstable in full forward to full reverse (and similar) maneuvers, or when using long and/or tall arms.
6wd effectively shortens the wheelbase to 1/2 the length of the robot, due to the fact that it only rides on 4 wheels at a time. However, it regains the stability of the long wheelbase robot because of the extra 2 wheels at the other end of the bot. Add to the fact that all 6 wheels are powered, and you have a drivetrain that optimizes a long and short wheelbase robot.
Pushing power between a 6wd and a 4wd should be no different, as only 4 wheels are on the ground at a time for both robots. (also assuming the same motors, gearing, wheels, etc...) We used 6wd for the 1st time last year, and it served us extremely wheel. YMMV. Best of luck.
BEN
4wd vs 6wd? Yov Technical Discussion 22 06-01-2005 00:09
confirmed... 6WD recommendation of Joe J.. archiver 2001 0 23-06-2002 23:20
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
