Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
View Poll Results: Is your team going aftr the ramp this year?
Yes, we are going after the ramp 211 90.95%
No, we are not going after the ramp 10 4.31%
Ramp??? What ramp? 11 4.74%
Voters: 232. You may not vote on this poll
Unread 01-02-2006, 14:04
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Teams going after the ramp?
We are planning on installing a parking brake on one wheel. To mount the ramp we are going to hit it at an angle as fast as we can, engage the parking brake and slide sideways into our parking spot. This way we don't have to worry about tilting backwards! The key component to this plan is speed though!
Unread 01-02-2006, 14:10
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Here is a video of Team 1480 parking their robot.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 01-02-2006, 21:50
AKA: Dan
RATS! I guess yall beat us to our idea already!
Unread 01-02-2006, 14:07
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Team Role: Leadership
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
something i just thought of. you can use the reverse method. how about instead of pinning an opposing robot on you ramp, sit on their ramp and prevent them from coming up. that gives them 5 points but not 25.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 01-02-2006, 14:22
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
If you can prevent all of them from getting up the ramp this might be something to look at. However, remember you have just given them 5 points, and taken 15 points away from your own alliance. If you are successful in blocking them, the net is +5 for your alliance. But if they can get one robot on the ramp despite your maneuvering to block, the net effect is 0. You would have achieved the same result if you ignored their ramping attempts and just focused on your own end.
If you know they can't get at least one of their robots on their ramp, you will come out +15 by getting all three on your own ramp.
You may be able to block the other alliance and then scoot off their ramp at the last second, thus depriving them of the 5 points your bot would have scored. Even so, not much gain for a risky strategy.
Unread 01-02-2006, 14:42
Modulardragon's Avatar
Modulardragon Modulardragon is offline
FRC #1236 (Phoenix Rising)
Team Role: Mechanical
Modulardragon is an unknown quantity at this point
Since i'm seeing a lot of out-of-the-box ideas, what about this? If your robot can shoot well and time's running down, dump a load of balls on their flat part of the ramp. it prevents them getting on the ramp :S. I know its a little bit of a point loss, but it could be worth it.
Unread 02-02-2006, 21:42
blaskay16's Avatar
blaskay16 blaskay16 is offline
President/Driver
AKA: Jeremy
FRC #0815 (Advanced Power)
blaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these parts
Send a message via AIM to blaskay16 Send a message via Yahoo to blaskay16
we at team 815 can go up the ramp from a sitting position at the base of the ramp while carrying 120 lbs. this was one of our main goals
Unread 02-02-2006, 22:41
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
With out any obstructions (balls - other robots) it's relatively easy to go up the ramp straight on. Try it at an angle approach with the robot at competition weight . It's a little more interesting
Unread 03-02-2006, 10:06
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
I really have to agree with you there. You are basically testing how well your robot can perform under crappy conditions.
Originally Posted by DjAlamose
But then again gyroscopes... gyroscopes...
What about gyroscopes? Oh yeah, are any teams attempting to have their robot shoot from the ramp?
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 01-02-2006, 11:05
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Originally Posted by Abwehr
I'm of the school of thought that any robot can make it up the ramp if they're going fast enough
The problem with this school of thought is that in practice it doesn't work. When you are running at the ramp at a great velocity, you will hit the steep ramp and essentially bounce back. If what you meant to say was that "If you are going fast enough when on the ramp" then that's funny (seriously).
[QUOTE = antthecyberguy]Our original thought was that of "the ramp is not worth it" but our robot design allows to go up it if necessary. We would hate to be the only one in the alliance that could not make it.[/quote]
I'm absolutely in agreement. You don't want to be the "downer" on your team that can't get up the ramp at the end, especially if your teammates are counting on you. Nicely said.
Paul Dennis
Unread 01-02-2006, 12:07
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Team Role: Teacher
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
And you'd be alot more vaulable if you got the torque and the design to help your other alliance robots get up the ramp
Help other alliance. We plan on pushing the other teams robots our ramp just to make sure we get 25 points and they don't, that is a big swing of points.
and if they are stuck on your ramp they can't score and there are no pinning on the ramp.
Question is how many robots can you push up the ramp in 40 seconds
power, speed nice
Building FIRST robots since 1995
BVT Robotics
Unread 01-02-2006, 13:21
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
Rookie Year: 1998
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
My guess is one. Unless you can co-ordinate with your alliance partner to hold the first on in place while you go get the second. And after the first one the other guys might decide to stay away from you.
Unread 31-01-2006, 16:07
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
We're planning on it; time will tell whether the CG of our machine allows it.
Our team brainstorming came to the same conclusion as another poster in this thread - that if your robot can get up the ramp, you make yourself a valuable alliance partner to another team that also thinks it's important.
We saw many games in Triple Play that hinged on the 10-point bonus at the end of the match. Those 10 points were equivalent to a single completed row. The 25-point max team bonus this year equals a lot of balls in the goal. It could be important.
Unread 31-01-2006, 16:09
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
  #15   Spotlight this post!
Unread 31-01-2006, 16:24
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
We will just speed toward the ramp but with the new traction wheels our robot has it might be able to grip onto the metal...either way we have brakes that will lock the robot in place so we won't roll of the ramp..we might be able to push "other robots" onto the ramp too
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
Finding new teams Kit Gerhart Finding A Team 8 13-04-2004 12:05
The top 8 teams will be....(2004) Jessica Boucher General Forum 20 24-03-2004 22:31
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
