speeding up the work on 3ds MAX (and then some)
I tried the search for the Q&A and didn't come up with anything
then again I'm not that good with searches... anyways, we have a build a few models for our animation and have put the materials on them, the problem is if I try to modify them or animate (not render, just like make them move) and/or move the perspective view point around, it all moves VERY slowly, making my work go even slower if I press J (or f3 I forgot which one is it) the materials and colours go off in the screen but it still all move very slowly, and is very heavy on the computer what can I do to make 3ds max work faster? any way to ignore materials for now?, thanks... =) another problem I'm having is (well 2 more) is when I use GLOW effects the glow goes through the material for example: I put the glow on a oil tank primitive object (extended?) and then put the oil tank inside a tube put glow on the oil tank and the glow is seen from all sides of the tube (not just the tips as I want it to),+is the inferno affects something that moves when animated? last one:when I look around in the perspective view port and I press that circle button (buttom right) to move around, sometimes it moves all over the place and I have to undo all of my view port changes inorder to restore control over the device, is this a bug? or is there a way to fix it? thanks all and have a good week |
| Autodesk Codec Response!!! | Specialagentjim | 3D Animation and Competition | 37 | 15-03-2003 19:57 |
| No!!!!!!!!!! | rbayer | Programming | 41 | 05-01-2003 18:41 |
| FIRST MAX Animation Tutorials | Robby O | 3D Animation and Competition | 2 | 01-02-2002 22:53 |
