Go to Post Now, if that team were to split...would it be dividing by zero? - Karibou [more]
Unread 31-01-2006, 22:42
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Nothing But Dewalts Issue
We have been implementing the shifting transmissions described in the seemingly very popular "Nothing But DeWalt's" whitepaper. While some of the instructions are a bit ambiguous (I'm a programmer, so I'm just passing this on), we've had no issues until now. Following the instructions to increase the bore size of the "carrier sun gear" (the one which attaches to the output shaft of the CIM) we sent said part to a machine shop (we didn't trust ourselves to do it, as the metal is so thin after this operation is completed). One of them came back just fine, but on the other the small portion of the sun carrier gear (what I suppose is the "sun") came clean off when the machinists tried to machine it. We're going to run the other one some time this week and see if it too fails, and we've ordered replacement parts to give it another go.
Has anyone else had this issue?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 01-02-2006, 21:49
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
Re: Nothing But Dewalts Issue
Our four went perfectly, though our machinist broke several bits trying to get through the gear (it's extremely hard stuff). I will once you get them on though, they really are awesome. We probably won't shift because the work so darn well in first, we don't need to.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 01-02-2006, 22:11
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Thanks for pointing this problem out.
This is one of the trickiest parts to make.
The part is hard and the wall that is left is very thin*. The machinist needs to take very small cuts with a carbide boring bar or (my perference) you need to find a good wire EDM source.
Joe J.
*in fact it was so thin, there is no engineer I trust that says it should work, I myself doubted it would hold up, but thankfully, testing is the ultimate authority.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 01-02-2006, 22:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Rather than creating a new thread, I'll post here. We are using a fisher price and Dewalt tranny. Is it backdriveable from the factory? If not, how do we make it backdriveable? Does doing so have any bad event on robustness or anything?
Unread 01-02-2006, 22:26
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
If you leave the 5 rollers (or any 1 of the 5) in the front end of the transmission, it will not be backdriveable.
I have had an experience where the outside ring of the transmission cracked and the no-backdrive feature failed. Notice it is not the RING GEAR that cracked but a special ring made to provide the no-back feature required for a keyless chuck. The transmission still worked, it just did not remain in place after power failure.
It was definitely a high stress application and it only failed once (and I think that Dewalt subsequently changed the design of the ring to reduce a stress riser in the part -- if memory serve me well), but it did fail.
It can cause your feedback loops to go into fits if you leave them in, especially with large arms that are not well counter balanced.
Bottom Line: if I can, I take them out.
Joe J.
Mentor
Team #88, TJ2
Unread 01-02-2006, 22:38
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Originally Posted by Joe Johnson
If you leave the 5 rollers (or any 1 of the 5) in the front end of the transmission, it will not be backdriveable....
Joe J.
931 experienced this problem using the DeWalt transmission with an FP motor to lift an arm last year. With the anti-backdrive rollers in the arm was stable while raising and erratic while lowering. Removing the anti-backdrive rollers cleared the problem.
Richard Wallace
since 2003
Unread 01-02-2006, 22:37
groves groves is offline
Steve Liggett
None #1213 (Groves)
Team Role: Teacher
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
Joe J.
This is what we do. we have this cut and we remove the planets and the four smaller holes go on those little shafts that the planets had fit to. plus if you mess up this piece you can just cut another one. we have had no problems with this mount (on eight drive platforms) at all! now as far as machining Dr. Johnson is correct these should be cut with a wire EDM or a water cutter works for these disks.
Heroes of Engineering Comic: Dean is the December Issue Vince Dean Kamen's Inventions 5 01-12-2005 12:00
**FIRST EMAIL**/FIRST Newsletter, 2005 Issue #3 Rich Wong FIRST E-Mail Blast Archive 1 04-10-2005 10:24
**FIRST EMAIL**/FIRST Newsletter, 2005 Issue #1 dez250 FIRST E-Mail Blast Archive 0 03-06-2005 15:02
FIRST Newsletter - 2004, issue #3 Andy Baker FIRST E-Mail Blast Archive 0 22-09-2004 14:17
Mentors, is there an issue with how you pay for your Championship package? Natchez Championship Event 4 09-03-2004 03:49
