How do you mount the encoders to the Gear boxes?
I have not found any documentation about how to mount the encoders to the gear boxes. Does anyone have any suggestions or info about this?
Waialua Robotics |
Re: How do you mount the encoders to the Gear boxes?
Ours has threads and a nut just before the shaft, so we drilled a hole a certain distance from one of the gearbox shafts allowing a plastic gear on the encoder to mesh with a brass gear on te shaft. Your encoders could be different so i dont know if i'm being much help.
We actually put a small spur gear on the encoder and have it spinning as a dummy on our gearbox. Works great.
There are some pictures in the manual and on the IFI site.
Try it out...it's relatively self explanatory. |
Last year 234 took the output shaft down outside of the drive gearbox to the diameter of the encoder and then attatched heat shrink tubing between the two shafts to relieve stresses on the encoder. This worked quite well, but we ended up not using becuase we didn't drive last year in autonomous.
| Gear tooth sensor vs. Optical Encoders | Avarik | Programming | 7 | 01-17-2006 10:18 AM |
| pic: GEAR BOX with two speed | ericwittlich | Extra Discussion | 6 | 07-19-2005 10:01 PM |
| gear boxes | BoticsPUNK | General Forum | 6 | 01-24-2003 08:35 PM |
| FISHER PRICE GEAR BOXES | archiver | 1999 | 2 | 06-23-2002 10:07 PM |
| the motor mount with gear switch | newatthis | General Forum | 4 | 01-15-2002 10:07 PM |
